trans case tricks?
Old Feb 22, 2007 | 10:12 AM
ykracing's Avatar
Default trans case tricks?
Hey guys, just thought I would ask if anybody had any tips/tricks for getting the trans case back on...
I have done it a bunch of times, but it always takes maybe 2-3 tries before I can get it to sit down properly... and for some reason its really fighting me this time...
any suggestions, or maybe things I may not a have thought of?
for example, someone mentioned that it should be in a certain ger or something, but I've never done that before...
anyways, any help would be appreciated...
Old Feb 22, 2007 | 02:25 PM
Mistermark's Avatar
make sure the flywheel bearing and pressure plate/clutch is all aligned well.
other than that, lift and wiggle it around till it goes in
Old Feb 22, 2007 | 02:58 PM
ykracing's Avatar
Default Re: (Mistermark)
I meant the tranny case, not installing the tranny on the engine... but thanks.
Old Feb 22, 2007 | 08:45 PM
SlowReaction's Avatar
Default Re: (ykracing)
I dont know if theres a trick to it but it take a few trys for me also. Just make sure everything is lined up and make sure the c-clip is expanded. After a couple wiggles it usually pops in place.
Old Feb 23, 2007 | 04:25 AM
ykracing's Avatar
Default Re: (SlowReaction)
yep, as usual, on the third try, it slid right on.... I wish I could get it to happen on the first try at least ONCE in my life...
Old Feb 23, 2007 | 06:18 AM
IN VTEC's Avatar
I usually have to row it through 3rd and 4th to get the gear housing to drop because the shift forks get in the way.
Old Feb 23, 2007 | 11:39 AM
Gearspeed-Performance's Avatar
Default Re: (IN VTEC)
Sometimes you get luck on the first shot Most of the time it takes a couple taps and the 3rds a charm!
utn
27
May 22, 2007 06:59 PM
BLUE EH3
Jan 25, 2006 02:29 PM
si0385.
Dec 23, 2005 05:13 PM
1990civicsiguye
Dec 30, 2003 06:30 AM
02WRX
22
Jun 25, 2002 07:24 AM
