i think this is a stupid questin
Old Feb 21, 2007 | 07:07 PM
iwanttogofast's Avatar
Default i think this is a stupid questin
this is probably a stupid question but ive asked a couple of people, what exactly does a AEM adjustible cam gear do? i can find an awnswer for this question
Old Feb 21, 2007 | 07:14 PM
dad0c402's Avatar
Default Re: i think this is a stupid questin (iwanttogofast)
if you don't know what it does yet, it's prob best you don't mess with it till you do research. no offense but have you used the search function yet? I'm fairly new and I think it's in red font for a reason.
Old Feb 21, 2007 | 07:28 PM
Guam_CiviC619's Avatar
An adjustable cam gear on a single cam will allow you to "adjust" the powerband for better low end (advancing the valve timing) or more top end (retarding). On a dual cam you can gain power, they are best tuned on a dyno until the optimum setup is found. They are usually aluminum, which also lowers reciprocating mass.
Old Feb 21, 2007 | 09:26 PM
iheartjayDem's Avatar
^^ X2 well said
Old Feb 21, 2007 | 09:51 PM
crispy93's Avatar
VERY well said
Old Feb 21, 2007 | 09:52 PM
suspendedHatch's Avatar
It doesn't do a whole lot until you get an aftermarket cam or two.
Archidictus's Avatar
Unceasing Measure
Default Re: (Guam_CiviC619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Guam_CiviC619 &raquo;</TD></TR><TR><TD CLASS="quote">An adjustable cam gear on a single cam will allow you to "adjust" the powerband for better low end (advancing the valve timing) or more top end (retarding). On a dual cam you can gain power, they are best tuned on a dyno until the optimum setup is found. They are usually aluminum, which also lowers reciprocating mass.</TD></TR></TABLE>
Quick addition: This is how one goes about adjusting the mechanical timing of an engine. The ignition timing has nothing to do with this, so don't get the two confused
Also, SOHC or DOHC, they should all be tuned on a dyno for the best results.
bigsnorlax
Apr 20, 2009 09:18 AM
nutball72
Aug 21, 2006 01:47 PM
hks_Racing
Feb 15, 2006 09:33 PM
Guam_CiviC619
Oct 12, 2004 11:25 AM
Loco Honkey
Oct 28, 2002 04:51 PM
