taking the motor out
Old Feb 21, 2007 | 01:07 PM
powerdbygarrett's Avatar
Default taking the motor out
im gonna take my motor out tonight so i can give it away to be built, i just had a few questions about it.. the correct steps would be to unbolt everything, take the axle out, take the trans out then stap on the the engine crane, then undo the motor mount bolts, and the just lift right? or am i missing something.. any more indepth help would be great. thanks
Old Feb 21, 2007 | 02:11 PM
PrecisionH23a's Avatar
Default Re: taking the motor out (powerdbygarrett)
Drain oil/coolant/trans fluid
Undo all hoses/etc.
Remove intake/ex mani/dp/ps/ac
pull axles
hook engine up on the cherry picker
remove motor mounts (dissassemble the tranny one in 2 parts)
pull engine/tranny at an angle with the tranny lower then other side
Old Feb 21, 2007 | 02:47 PM
so the engine and the trans has to be pulled together? no way to take the trans off first then pull engine?
Old Feb 21, 2007 | 02:56 PM
Default Re: (powerdbygarrett)
pull it at once... unless you have time to waste.
Old Feb 22, 2007 | 08:06 PM
can u give me a lil more detail on how to pull the axles and the motor mounts. ohh and is it absolutly nessessary to take the intake manifold off?
Old Feb 22, 2007 | 08:43 PM
swoll82's Avatar
no u dont need to take the intake manifold off, just the air intake. The motor mounts are just basically big bolts. u shouldnt need anything other than just the right socket or wrench. Once u have the engines weight supported by the cherry picker they should be easy to remove. dont forget to disconnect all the wiring harness connectors and have an idea of how they were set up. (even though I dont think that many, if any of them will fit in the wrong place) when u say u r giving the engine away to be rebuilt do u mean they are rebuilding it for you or do u mean that they are keeping it and you are putting in a new engine? oh yeah and one more thing, if you dont have a engine leveler I would reccomend borrowing one before you go to put the engine back in. it will make your life a lot easier.
Old Feb 22, 2007 | 09:24 PM
petern101's Avatar
Default Re: (swoll82)
this would be much easier if you read the engine swap faqs
Old Feb 23, 2007 | 09:51 AM
Default Re: (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">this would be much easier if you read the engine swap faqs</TD></TR></TABLE>
i looked actually couldnt find the thread for some reason, can u link it? thanks
Old Feb 23, 2007 | 07:20 PM
petern101's Avatar
^it should be in the faq section. but then i looked......and it wasn't there anymore
they have changed that link page since i've been on here (4 months)
sorry buddy. if not, i would suggest a helms manual. everyone needs one
Old Feb 26, 2007 | 09:04 PM
dam this is a retarded processs
Old Feb 27, 2007 | 07:07 PM
ok im stuck, ive tried torching, greasing, 150psi on the compressor, anything i could to undo those dam axle bolts and they still dont wana come off.. any advice?? thanks
Old Feb 27, 2007 | 07:15 PM
Max Kling's Avatar
Cut top of bolt off with grinder, air chisel the nut off, will prolly also mess up the threads on the end of the axle though.
Old Feb 27, 2007 | 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett &raquo;</TD></TR><TR><TD CLASS="quote">ok im stuck, ive tried torching, greasing, 150psi on the compressor, anything i could to undo those dam axle bolts and they still dont wana come off.. any advice?? thanks</TD></TR></TABLE>
Buy a real impact gun or get a big *** 1/2" drive breaker bar.
Old Feb 27, 2007 | 07:46 PM
CGags13's Avatar
i learned you should always crack the axle nuts loose first...put the car on the ground..preferably not smooth garage floor concrete
Old Feb 28, 2007 | 04:53 AM
championshipwhite93si's Avatar
Default Re: (CGags13)
its real easy for the castle nuts on the axles.. if you have a centercap on your wheels that you can take off and see the nut, take it off, have someone hold the brake pedal, and go after them with a 1/2 inch breaker bar. easy as pie
Old Feb 28, 2007 | 10:22 AM
tried a big *** breaker bar too guess i should try a biggger
Old Feb 28, 2007 | 12:10 PM
4thgenner's Avatar
grab a cheater bar (i use a spare piece of exhaust pipe laying around)
Old Feb 28, 2007 | 12:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerdbygarrett &raquo;</TD></TR><TR><TD CLASS="quote">tried a big *** breaker bar too guess i should try a biggger</TD></TR></TABLE>
Add a pipe like someone else mentioned so you can create more torque.
Have someone hold the break and basically you will stand and jump on the other end to break the bolt loose.
Just make sure when you break it you have something to catch your fall.
jaymua
Jan 31, 2009 08:51 PM
grimace007
May 23, 2007 05:40 PM
LukieLuc
Apr 12, 2007 11:49 AM
RSVTECDC4
Nov 17, 2004 01:18 AM
Accord94DX
Jun 13, 2002 03:25 PM
