Coil on plug ignition
Old Feb 21, 2007 | 12:44 PM
classic86crx's Avatar
Default Coil on plug ignition
Hello, I am currently a student a pct. I was am very interested in creating a time attack car using my current crx. My upcoming mods for the summer is a b16 with obd 1. As I was in school I learned about coil on plug ignition. I am thinking about coverting the engine to coil on plug ignition which allows every spark plug a get its on coil pack directly over the spark plug. I know I would need the sensors and the ignition module. But I was wondering does anyone know someone that has tried this setup before. By creating this setup spark will be much more reliable and be controlled by a computer. There less moving parts which can make the system more duriable. What do you guys think?
Old Feb 21, 2007 | 10:32 PM
...esteban's Avatar
Princess
Default Re: Coil on plug ignition (classic86crx)
this has been done alot. User name Tony1 runs a shop in Tx and has a kit to do just this.
http://www.t1racedevelopment.com/ From what I've read/seen, a non-honda ecu is required (i've only seen this used with the AEM EMS) to be used with this. It takes some $ to get the parts etc, however its a topnotch ignition setup...however I think this setup might be overkill for a mostly stock motor...the stock dizzy isnt all that bad
Old Feb 22, 2007 | 11:34 AM
njn63's Avatar
Default Re: Coil on plug ignition (...Lost)
stock dizzy is fine for what you're doing i can guarantee. Most of the setups i've seen use CBR (motorcycle) coils and an AEM or similar EMS.
Joyfulchap
May 17, 2018 08:10 AM
JDMlyfestyle
Apr 25, 2005 01:12 AM
EKCivicR
Nov 24, 2004 05:35 AM
B20-T
Jun 9, 2003 03:58 PM
