Honda S2000 Honda S2000
if lowering no more then 1.5" do you need the drive shaft spacers..did search but no specifics found
Old Feb 21, 2007 | 09:56 AM
LVCURVS's Avatar
Default if lowering no more then 1.5" do you need the drive shaft spacers..did search but no specifics found
Just want to lower my '02 no more then 1.5" and that's at the most. How low can you go with out having to use the driveshaft spacers? I searched and all i can figure out is that if you lower past a "certain point", you need them because it causes accelerated wear etc... I don't drag race but do track day it and dd it.
Old Feb 21, 2007 | 10:06 AM
LAS2K's Avatar
Default Re: if lowering no more then 1.5" do you need the drive shaft spacers..did search but no specifics f
1 inch and lower you need half shaft spacers.
Old Feb 21, 2007 | 10:13 AM
S2SLOW's Avatar
No, Im lowered over 3inches and dont need them.....
Old Feb 21, 2007 | 10:58 AM
cmdr430's Avatar
it cant hurt.....on 00-03.....
iirc 04 and up have extended axles already so depending on how low you go you may or may not need them.....
i am lowered 1.5 and have not heard or seen anything excessive at this time..... just keep an eye on it.....
Old Feb 21, 2007 | 11:25 AM
papa5murf's Avatar
Not "needed", but doesn't hurt. But it's worth having in the long run.
Old Feb 21, 2007 | 11:27 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">No, Im lowered over 3inches and dont need them..... </TD></TR></TABLE>
That's what you think. Anything over 2 inches is highly recomended to have them. Otherwise you'll start replacing parts sooner then later.
Old Feb 21, 2007 | 11:34 AM
S2SLOW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">
That's what you think. Anything over 2 inches is highly recomended to have them. Otherwise you'll start replacing parts sooner then later. </TD></TR></TABLE>
Replaced the inner joints long ago, it was vibrating at stock height and 30,000 miles kinda weird....
Old Feb 21, 2007 | 11:46 AM
Mr. Projekt's Avatar
* B A N N E D *
Never really know til you take them apart and check them out. S2SLOW doesn't drive his car much... yet.
Old Feb 21, 2007 | 11:49 AM
S2SLOW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
Never really know til you take them apart and check them out. S2SLOW doesn't drive his car much... yet.</TD></TR></TABLE>
Much, it rolled over 86,000 yesterday on an 03......and has been Hammered since a little over 30,000.....and yet no problems!!!!
Well 1 problem tire wear.....lol
Old Feb 21, 2007 | 12:19 PM
LVCURVS's Avatar
ok,kool. thanx
Old Feb 21, 2007 | 12:46 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Not "needed", but doesn't hurt. But it's worth having in the long run. </TD></TR></TABLE>
Old Feb 21, 2007 | 01:21 PM
* B A N N E D *
Well 1 problem tire wear.....lol </TD></TR></TABLE>
You said you had it put away in the winter, so I assumed. Yea yea I know...
I guess you have Wednesday-made driveshafts.
Old Feb 21, 2007 | 01:39 PM
S2SLOW's Avatar
I guess you have Wednesday-made driveshafts.</TD></TR></TABLE>
Yea i sold my ej1 so i have to drive everyday and i think it was made on tuesday....
faiz_23
Suspension & Brakes
Apr 14, 2005 03:44 PM
streetsweaper
Sep 20, 2004 07:08 PM
HondaRcB
May 30, 2003 05:11 AM
citanest
Oct 31, 2001 05:15 PM
2005 TSX
Jul 26, 2001 05:08 PM
