ngk spark plug part #
Old May 20, 2002 | 05:27 PM
carcala's Avatar
Default ngk spark plug part #
anyone know what the part # for the ngk non-platinum plugs are? Thanks
Old May 20, 2002 | 06:55 PM
GreenD's Avatar
Default Re: ngk spark plug part # (carcala)
i use bkr6e-11.
Old May 20, 2002 | 06:56 PM
carcala's Avatar
Default Re: ngk spark plug part # (GreenDestiny)
what kind of motor?
Old May 20, 2002 | 06:58 PM
sloaccord96's Avatar
huh which car?
ZFR5F-11 for the accords
thats for 3rd-6th gen accords (i4 + v6, except for 6th gen v6)
Old May 20, 2002 | 07:02 PM
carcala's Avatar
Default Re: ngk spark plug part # (sloaccord96)
for the b-series motors.
Old May 20, 2002 | 07:10 PM
GreenD's Avatar
what kind of motor?
b18c1
Old May 20, 2002 | 07:11 PM
carcala's Avatar
do they run good? How long do they last till you would have to replace them? thanks
Old May 20, 2002 | 08:57 PM
GreenD's Avatar
so far i havent had any problems. your supposed to change coppers every 15k or so. ill probobly swap em at 10k. the stock platinums(pfr6g-13) are good for 60k but also cost 6x as much.
also search the archives, youll learn alot more than what i can tell u.
[Modified by GreenDestiny, 10:06 PM 5/20/2002]
Old May 20, 2002 | 09:07 PM
ZFR5F-11 - for the b18b
(plat) PFR6G-13 - for the b18c series
do they even make a non-platinum style for the b18c series?
try: ZFR7F-11
*shrug*
Old May 20, 2002 | 10:10 PM
Halo's Avatar
the BKR7E comes on the jdm B18c
Old May 20, 2002 | 11:00 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: ngk spark plug part # (Halo)
one of the best plugs that i have come across for a modified honda b series is the NGK-R bcpr7e-11 i prefer colder plugs especialy with headwork and or more compression.
Old May 20, 2002 | 11:38 PM
kinesistech's Avatar
Default Re: ngk spark plug part # (HOOKUPS-PRO-CRX)
The only plugs I use on modified engines are NGK BKR7E's tell the parts guy you need ngk 6097. If you say bkr7e he will go into that state that confused parts guys go into when you tell them what you want instead of what they think you need.
mysterysktr7
Dec 14, 2008 06:49 PM
WhiteVX
Apr 22, 2007 02:08 PM
volkracing99
Mar 20, 2006 10:07 PM
stupidfast
Dec 30, 2002 07:29 PM
