oil filter relocation kit question....
Old Feb 20, 2007 | 02:02 PM
JDM SLICK's Avatar
Default oil filter relocation kit question....
i am planning on purchasing a greddy oil filter relocation kit for my ej and i told my engine builder about it....he said it's a bad idea because it'll cause the oil pressure to drop lower than normal since the oil will have more distance to travel.
he said the only time one would put an oil filter relocation kit is when you're running an aftermarket oil pump cause it'll compensate for the increased travel of the oil to reach the engine...
kinda make sense since the oil has to cover more distance....but what are your take on this? will it drastically lower the oil pressure??? i wanna buy it because it makes oil changes a hell of a lot easier and it looks cool on an engine bay
any suggestions would be nice...
Old Feb 20, 2007 | 02:25 PM
havok hybrid's Avatar
Default Re: oil filter relocation kit question.... (JDM ***)
I have always wanted to know that same. I want to add a front mount oil cooler. I'm worried about that same thing.
Im worried about oil volume and pressure loss. Anyone have and data on using these setups on Stock OEM oil pumps... Along with the amount of oil psi you would loose with these systems?
Old Feb 20, 2007 | 08:48 PM
JDM SLICK's Avatar
anyone?
Old Feb 21, 2007 | 12:59 PM
Default Re: oil filter relocation kit question.... (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I have always wanted to know that same. I want to add a front mount oil cooler. I'm worried about that same thing.
Bump
Old Feb 21, 2007 | 06:09 PM
dfoxengr's Avatar
i do not believe therell be a large pressure drop.
what kind of drop are you asking about also? the entire system? to the filter?
throughout the whole system, the pressure should remain constant regardless of the minute(respectively) volume of the added lines.
Old Feb 22, 2007 | 12:50 PM
JDM SLICK's Avatar
Default Re: oil filter relocation kit question.... (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">i do not believe therell be a large pressure drop.
throughout the whole system, the pressure should remain constant regardless of the minute(respectively) volume of the added lines.</TD></TR></TABLE>
so in summary, it won't affect the oil pressure throughout the whole system then....
Old Feb 22, 2007 | 01:36 PM
bump for more Data.. This needs to be covered!
Vtec-Mini
Dec 11, 2011 03:50 AM
Pooby88
Sep 1, 2007 01:53 AM
turbotime
Oct 20, 2006 12:03 PM
JDMTurboCivic11
Oct 26, 2004 07:18 AM
h23accordlude
Jun 3, 2002 06:35 AM
