MY S/C SI
intake and header will definitely increase that number by alot. when they say an intake will add 8hp, it wont do it stock but then on a supercharger it really will. and didnt will get 11hp from his header? what gear was it dynoed in? 3rd or 4th? i hear 4th is the best. either way, still looks sick!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo2Vtec »</TD></TR><TR><TD CLASS="quote">So a NA SI, with SSR header and intake exhaust/Reflash makes more HP and Tq? lol </TD></TR></TABLE>
No, that was flywheel Hp in that thread. They said wheel HP should be around 205.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo2Vtec »</TD></TR><TR><TD CLASS="quote">No it wasn't flywheel hp, it was measured at the hubs. </TD></TR></TABLE>
Hub HP is going to measure much higher than on a dyno jet, the 218hp from the supercharger is on a dyno jet. So the 225hp on the hub dyno is lower than the 218hp
Here ya go
http://www.8thcivic.com/forums...nt=23
Here ya go
yeah...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Comptech Supercharger- clean as all of you know from previous. roots type SC pushin 4-6psi. around 50whp with stage one bolt on kit. Dyno's will run anywhere from 230-240 whp just sc kit.(recomended to use intake, header and exhaust with SC kit.
Comptech reflsh- This reflash is done by hondata. made for their supercharger it pulls like a bat out of hell with this. highly recomended. i dont have dyno sheets on this but from other hondata alone dynos i have seen 20-30whp in certain rpm ranges.
That is not a hub dyno--that is a Dyno Dynamics which uses two small rollers instead of the one big one like a Dynojet. They tend to read lower--I dynoed 10 less whp on a dynodynamics compared to a dynojet-157--166-same exact setup.
Wait what? You don't have the included hondata/comptech reflash?
You seem to be running a bit richer than I am...
Also, I found that this kit pushes between 2-5psi depending on RPM (this is at altitude btw)
BearsEK-KMSU
20
Nov 29, 2007 11:08 AM
