spark plug tips pure white!!
Old May 20, 2002 | 01:30 PM
mugenracer's Avatar
Default spark plug tips pure white!!
seeing as my car is off the road for a few days i decided to change plugs/leads/vtec solenoid seal etc..anyway when i pulled the plugs out the tip/electrode is pure/bright white almost like chalk dust..which means i'm running too rich and is obviously adding to my oil consumption problem (3-4 quarts every 5k) so how do i change the mixture to a less rich/leaner mixture. BTW the plugs have only been in the car less than 5k, theyre denso iridium plugs, i checked the old NGK ones i had taken out before putting in the densos and they are a light/medium brown colour which suggests that theyre were ok...so what is causing the mixture to run rich as i havent changed anything else on the engine?
Old May 20, 2002 | 02:05 PM
Erik_Pb_Foot's Avatar
New User
Default Re: spark plug tips pure white!! (mugenracer)
You are running WAY lean if they are white, not rich. FPR would be a good start. What are your mods?
New User
Default Re: spark plug tips pure white!! (Pb_Foot)
and when you replace them this time, NGK's all the way. I forget the model# if someone can fill that in for us. Thanks
-Erik
Old May 20, 2002 | 02:19 PM
mugenracer's Avatar
i bought a set of NGK Bk6Re (i think) anyways its the ones marked on the side of the valve cover so theyre the correct ones. I have a mugen cat back system, caldo honda hi flow cat, and blitz intake, everything else is stock
sorry for being dumb but what is FPR...fuel pressure regulator???
Old May 20, 2002 | 02:23 PM
TurboSedan's Avatar
New User
Yeah, FPR=fuel pressure regulator.
Old May 20, 2002 | 02:40 PM
mugenracer's Avatar
Default Re: spark plug tips pure white!! (97CivicFerio)
i've done the search and cant find what i need...so how do i adjust the fuel pressure to make the mixture less rich...sorry again for beind dumb but i only seem to know about things that i've done myself in the past!!
Old May 20, 2002 | 03:17 PM
New User
get those shitty plugs out asap and put in the NGK's. go to school/work/grocery store and when you get back home check them again. They could have been incorrectly gapped, but I dunno much about the effects of incorrect gapping.
Do you hear any pinging from your exhaust?
Let us know what the verdict is.
-Erik
Old May 20, 2002 | 03:21 PM
ALLMOTOR18's Avatar
why you running lean?. what ecu you running? do you have a VAFC?
Old May 20, 2002 | 04:14 PM
prelude-bb3's Avatar
Default Re: spark plug tips pure white!! (GSRTypeR)
his plugs are causing this behavier,nothing else,before changing to an adjustable FPR (Apexi) Power/Kingboost etc,replace the plugs with the NGK original ones!!!!
if u were then going lean ....post again
Old May 21, 2002 | 06:39 AM
88_SC_CRX_Si's Avatar
New User
Those types of plugs iridium/platium(sp) ect... Have more resistances built into them, due to the material there made of. However, Honda's are suppose to have one of the better OEM's out there, when it comes to ignition components. Sooo, thats telling me you have a break down in the coil or the igniter, etc...
Just my thoughts...
Old May 21, 2002 | 06:50 AM
TypeR_853's Avatar
stock NGK platinum = best all around, even for oem!!!
iridium = not worth the $$$, several bad experiences from other owners...
copper = good performance, bad life
you should run a search...they're are a couple threads on this already...
Old May 21, 2002 | 07:27 AM
mugenracer's Avatar
thats what i'm trying to figure out, as i said, when i checked an older set of plugs they were light brown/tan colour, i havent changed anything at all in the car except for replacing the stock intake piping with mandrel bent intake pipe, but i'm still using the blitz filter i had on the stock piping. I did start to get a spitting/burbling from the exhaust when going downhill at low speed just letting the car ride in 2nd/3rd gear (foot off the accelerator) i just took this to be the exhaust internals burning out with use. NGKs are now in, but still havent got my coil so i wont know how the plugs are doing for a day or two yet.
milkwasabadidea
11
Aug 29, 2011 08:08 PM
axionm1k
Jul 17, 2008 05:02 PM
92DAIntegraXSI
Oct 30, 2006 12:44 PM
RTW DC2R
Mar 13, 2004 09:34 PM
euclid
Jun 20, 2003 02:33 PM
