How to remove moisture from the inside of my tailights?
Old Feb 19, 2007 | 03:49 PM
carboncivic's Avatar
Default How to remove moisture from the inside of my tailights?
Like the topic says, I took my car through the car wash a week ago, and theres still moisture in my tailights, and I was just wondering if theres an easy fix to dry it out inside of there?
Old Feb 19, 2007 | 03:51 PM
B16B_coupe's Avatar
HRD PKR
Default Re: How to remove moisture from the inside of my tailights? (carboncivic)
sit them in the sun.. or u can maybe sit them infront of a light. just dont let them get to to hot.. and then use clear silicon to re seal them!
Old Feb 19, 2007 | 03:58 PM
alacard's Avatar
Default Re: How to remove moisture from the inside of my tailights? (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">sit them in the sun.. or u can maybe sit them infront of a light. just dont let them get to to hot.. and then use clear silicon to re seal them! </TD></TR></TABLE>
thanks, i need to do this on my tails
Old Feb 19, 2007 | 04:00 PM
platinumx6's Avatar
Default Re: How to remove moisture from the inside of my tailights? (alacard)
get stock lights. i hope your oem ones arent leaky
reseal them if you want to keep them.
Old Feb 19, 2007 | 04:02 PM
alacard's Avatar
Default Re: How to remove moisture from the inside of my tailights? (platinumx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 &raquo;</TD></TR><TR><TD CLASS="quote">get stock lights. i hope your oem ones arent leaky
reseal them if you want to keep them.</TD></TR></TABLE>
not sure about the OP, but my stocks have water in them.
Old Feb 19, 2007 | 04:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">
not sure about the OP, but my stocks have water in them.</TD></TR></TABLE>
Yep, they were find just until a little while ago, then i noticed moisture in BOTH of them...
Old Feb 19, 2007 | 04:04 PM
B16B_coupe's Avatar
HRD PKR
some leak.. put the under a heat lamp. dont let them get to hot! and then re silicone them with clear silicone.. jezz stock headlights/tail lights do it all the time
totsie7944
Mar 28, 2008 12:31 AM
roundworldsobig
Sep 28, 2005 09:54 AM
Skelly
Aug 19, 2005 02:28 AM
murk593
32
Jul 19, 2005 11:57 AM
rocco
Oct 23, 2003 10:27 AM
