check engine light (tried jumping it with a paper clip but nothing happens) help!
Old Feb 19, 2007 | 03:37 PM
floatfisher's Avatar
Default check engine light (tried jumping it with a paper clip but nothing happens) help!
my exact problem is in the title. nothing happens when the paper clip is inside the little blue connector. its just a solid light. could that just be my code, or is it suppose to blink at least once???
details:
- the car has been sitting in the garage since December for storage
- decided to let it run today since its been 3 weeks since i last did it and the battery was dead, so i gave it a boost, and than the check engine light has been on ever since
any help would be great
Old Feb 19, 2007 | 03:44 PM
jetydosa's Avatar
25 Year Member
Default Re: check engine light (tried jumping it with a paper clip but nothing happens) help! (floatfisher)
you turn the car off and then back on (not cranked)?
Old Feb 19, 2007 | 03:51 PM
yes...what am i doig wrong
Modified by floatfisher at 5:02 PM 2/19/2007
Old Feb 19, 2007 | 04:14 PM
r573's Avatar
Default Re: (floatfisher)
What year car?
Old Feb 19, 2007 | 04:21 PM
Old Feb 19, 2007 | 05:13 PM
ITRDC2R's Avatar
take off one of your battery terminals for 10 seconds, and put it back on.. see if it clears it.
Remember to have your radio code handy, since it will reset your ecu..and quite possibly your radio.
Old Feb 19, 2007 | 06:27 PM
Padawan's Avatar
Darth ModerVader
Explain the procedure you are using to try to pull the codes.
Old Feb 19, 2007 | 06:31 PM
BLacK FirE's Avatar
Default Re: check engine light (Padawan)
You just might not be making the connection with the paper clip thats all. Try moving it around to make sure its connecting. It'll start flashing as soon you got it.
Old Feb 20, 2007 | 08:22 PM
Default Re: check engine light (BLacK FirE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE &raquo;</TD></TR><TR><TD CLASS="quote">You just might not be making the connection with the paper clip thats all. Try moving it around to make sure its connecting. It'll start flashing as soon you got it.</TD></TR></TABLE>
tried this...still cant get it to work....looks like im stuck taking it to a shop
Old Feb 20, 2007 | 09:13 PM
OG undercover's Avatar
Default Re: check engine light (floatfisher)
Don't take it anywhere just yet.
make sure there is nothing obvious wrong.
get the car fully warmed up.
make sure the battery is holding a full charge and the Alt is putting out the correct power with a multi meter.
IIRC if the car sits for a while it will throw a code for the hell of it.
Once the car is warmed up, shut it off.
then refer to the service manual
or try jumping it again while the key is in the "ON" position.
If that does not work, you are doing something wrong. STOP and have it done by someone who has preformed it correctly before.
Old Feb 20, 2007 | 10:39 PM
Circuit Star-29's Avatar
Default Re: (ITRDC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRDC2R &raquo;</TD></TR><TR><TD CLASS="quote">take off one of your battery terminals for 10 seconds, and put it back on.. see if it clears it.
Remember to have your radio code handy, since it will reset your ecu..and quite possibly your radio.</TD></TR></TABLE>
Can't clear codes like that w/ an OBD2 vehicle... You need a scan tool.
If you know anyone that works at Honda have them hook up the scan tool.
Old Feb 21, 2007 | 04:39 AM
Padawan's Avatar
Darth ModerVader
Default Re: (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Can't clear codes like that w/ an OBD2 vehicle...</TD></TR></TABLE>
Sure you can. I've done it a number of times on a '99 Civic Si and an ITR.
Old Feb 21, 2007 | 04:57 AM
BringIT's Avatar
try hammering the ends of the paperclip flat
if I remember correctly there are actually 4 slots on the connecter, 2 upper and 2 lower.. if it doesn't contact on the upper 2 holes use the lower 2
Old Feb 21, 2007 | 05:29 AM
Doostur's Avatar
Disconnect your battery for 30 secs or so .. it should work.
Old Feb 21, 2007 | 05:39 AM
exies's Avatar
Default Re: (Doostur)
If you cant jump it with a paper clip, you can try to borrow one from your local auto store. Most stores around here lend them to customers who turn in their license.
Old Feb 21, 2007 | 10:08 AM
Default Re: (exies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
cRAP...I was thinking of the SRS and ABS...
Carry on...
Old Feb 21, 2007 | 10:15 AM
andyt's Avatar
Default Re:
I like using one of these instead of a paper clip:
Old Feb 21, 2007 | 12:23 PM
Erik95LS's Avatar
Default Re: Re: (andyt)
or try a piece of wire, your paper clip might not be a very good conductor
Old Feb 21, 2007 | 08:27 PM
hayabusa160's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote"> I like using one of these instead of a paper clip: </TD></TR></TABLE>
haha i used to keep one in my wallet to check codes came in handy at times.
but now i got neptune i just flip the key on and put the throttle to the floor and any codes will come up
Old Feb 22, 2007 | 08:03 AM
mugenracer's Avatar
Have you the engine OFF but ignition ON when jumping the connector? You wont get the codes with the engine running.
BettyBlue21
Jul 4, 2018 08:46 AM
nyzd79
Nov 22, 2007 03:42 PM
alexb16hb
Nov 19, 2005 10:20 PM
laurat
Oct 14, 2002 12:54 PM
mkokwilson
Sep 17, 2002 04:22 PM
