93 Accord brakes and rotors
How do you remove the front rotors on a 93 Accord LX? I have the wheel off and the rotor is free from the hub. Do I have to remove the spindel nut and hub? Another friend the outer plate that bolts to the rotor should just pull off over the spindel nut, and then just pull the rotor off. It is not just comming off.
Please use the search and FAQ sticky. If you search, you'll find multiple thread on the subject and in the FAQ you'll find a tutorial on replacing the rotors.
Here's a recent thread about the brakes, remember 90-97 Accords have the same brake setup.
https://honda-tech.com/zerothread?id=1898213
I believe the brake tutorial is linked in that thread but I know for a fact the tutorial is in the FAQ.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joetravelall »</TD></TR><TR><TD CLASS="quote"> Thanks; I did do about three searches before I posted. Do not know why it did not come up or I did not see it.
That is it. Just what I was looking for.
You are not the first person disappointed with this programs search feature.
yeah, the search feature is based on the thread titles so that can sometimes make things difficult. Just remember to use different spellings of the word like... brake, brakes, rotor, rotors, ect. And also remember to search both the recent threads and archive threads. A lot of the stuff you'll be searching for will be found in the archives, but always search both to be sure.
SlowPokeEg
Jan 12, 2014 10:31 PM
LandHard
Aug 12, 2009 07:25 AM
