Timing Advance?
I just advanced my timing to 18 degrees. Here's my question, I had to move the distributor to the very end of the advance stroke in order to achieve 18 degrees. Anybody elses ITR like that as well?
It's not hard, all you need is a timing light. Make sure your engine is warm (rad fan running or has ran), ground out the service connector (the blue connector by the glove box), unbolt 3 bolts that hold the distributor down and move it till you got the desired timing.
Good stuff, I would like to advance my timing too... oh well. I'm patient.
Thanks
thats what i used when i did mine. they are good directions to follow
[Modified by Gravity, 8:03 PM 5/20/2002]
allnaturalb16
21
Aug 14, 2007 08:57 PM
