Installing Ls crank into a GSR
Help me out I was woundering when putting in a ls crank what rods do i use LS or gsr also are the 2 deck hights the same or will my pistons skick out a lil higher What all do i need to do to put a LS(b18b) crank in a GSR
Thanx guys and Yeah you would use ls bearings but its better to get you ls rods notch for gsr bearing . Their 2 advantages for using them
1. their smaller in with so their will be less friction and your motor will rotat faster and
2. the gsr bearings are maid for high reving motors so they will be more depndable
I have ls rods that are notch for sr bearings. I didnt think it would make that big of a difference but it does
