scan codes from a LS swaped 96 civic.
Old Feb 18, 2007 | 07:38 PM
7808's Avatar
Default scan codes from a LS swaped 96 civic.
i fixed up some wiring and went and scanned my car (that wouldnt scan before)
i got 4 codes.
2 were o2 sensors, probly one bad, secondary is not even there so thats alright
P0113 Intake air temperature circuit high input - bad IAT, ok
P1337 Crankshaft position sensor B fault (no signals) <- says that in print out
is this a sensor the ls motor doesnt have? or am i missing somthing? i thought those LS motors dont have this one
Old Feb 19, 2007 | 10:45 AM
sohc_coupe24's Avatar
Default Re: scan codes from a LS swaped 96 civic. (7808)
bump cuz im throwing the cps sensor too
Old Feb 19, 2007 | 10:57 AM
7808's Avatar
Default Re: scan codes from a LS swaped 96 civic. (sohc_coupe24)
does your motor have one? if so check the wires its right on the oil pump. my car doesnt have one..
i found this http://rywire.com/store/faqdes...c21cf
not sure if CPS and CKF are the same thing or what
Old Feb 19, 2007 | 10:33 PM
thanks i just did that with my integra. Unfortunately i can't tell if the code went away because I am throwing other codes as well, and i dont have an 0bdII scanner. However, the car does run more smooothly.
Old Feb 20, 2007 | 10:37 AM
Bakeoff's Avatar
on obd1 tegs, it's in the distributor. Try replacing it or swapping the guts from a known good dsitributor and you should be good to go. If you need one, hit me up on MNSC. My roommate has one.
Greasemonkey
14
Jun 7, 2004 03:20 PM
iluznxpnoi
Jan 10, 2002 10:17 PM
quickLSt
Aug 29, 2001 07:20 AM
