car wont start!! no fire! please help!
Old Feb 18, 2007 | 07:37 PM
ludatic98's Avatar
Default car wont start!! no fire! please help!
ok here are the facts:
the car i am working on is a 96 Prelude with the OBD2 h23a1 in it.
the motor that my customer gave me to put in came from canada and is a OBD1 h23a3.
i changed over the intake, distributer, and put a new OBD2 oil pump on it. (for the crank sensor)
when i went to start it up it doesnt get any fire. i checked, checked, and rechecked all of my plug ins, they are all good. i tested the coil and it is good, but still no fire.
the distributer will send one single spark when i first try to start it, but the fire goes dead after the first small spark every time.
another issue with this car in particular is that is was a flood vehicle that was purchased from the auction, i never got to hear the car run pior to them dropping it off at my shop, but they say that they had it running before they threw a rod.
i kno this is a long post, but it is a big problem as it has been in my shop way too long and i need to get it out.
any help would be greatly appreciated. thanks.
Old Feb 18, 2007 | 08:51 PM
PrettyLude's Avatar
man i would start checking at the crank sensor man, do you have any cels? how are all your grounds looking?
Old Feb 18, 2007 | 09:25 PM
nonvteclude's Avatar
Default Re: car wont start!! no fire! please help! (ludatic98)
have you checked the ignitor? a buddy of mine had a similar problem changed it and it fixed it. i have no idea where it is in a lude his was a civic. also have you tried a different distributor other than the one you swapped over?
Old Feb 18, 2007 | 10:44 PM
ludatic98's Avatar
Default Re: car wont start!! no fire! please help! (nonvteclude)
all of my grounds look good.
will the crank sensor cause it not to fire if there is something wrong with it?
also when i turned on the key i didnt notice any service engine light.
Old Feb 19, 2007 | 09:09 AM
ludatic98's Avatar
bump for more info.
Old Feb 19, 2007 | 09:20 AM
Silver Surfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the ignitor? a buddy of mine had a similar problem changed it and it fixed it. i have no idea where it is in a lude his was a civic. also have you tried a different distributor other than the one you swapped over?</TD></TR></TABLE>
ignitor
it's in the distributor....and since you changed that, you should probably check it out
Old Feb 19, 2007 | 12:54 PM
doubledeucehatch's Avatar
Timing???? I always check the easy things first.
Old Feb 19, 2007 | 02:51 PM
SikB's Avatar
Default Re: (prelude252)
I recently swapped an obd 1 h22 in to a 96 si and completely missed the sensors in the oil pump. I couldn't get a spark to save my life untill I ran those four wires op to the dizzy that came with the motor.
When you swapped out the oil pump for the one with the sensors did you change the sprocket too? The obd 2 sensor has a bunch of marks on it that the sensor reads. While the two sprockets are the same size they look very different.
edit: sprocket has a "c" in the middle
Old Feb 19, 2007 | 06:07 PM
PrettyLude's Avatar
the sprocket has magnets as you call it marks, and it reads it as a pickup, kinda like the hall effect
Old Feb 19, 2007 | 08:06 PM
ludatic98's Avatar
Default Re: (PrettyLude)
hey guys thanks for the help. i found the problem today. i forgot to change the sprockets i changed those out and it started right up.
thanks again for the input.
Old Sep 27, 2007 | 05:43 PM
accordlxr's Avatar
Default Re: (ludatic98)
hello i am having a similar problem only i cought it before i dropped the engine in. i have a 96 prelude vtec and for what ever reason my engine decided to grenade on me and now is just a really heavy paper weight. i got a jdm h22a to replace it and noticed that there is no crank sensors on the oil pump like the stock h22a1 had. i have read something about taking the wires from the crank sensor and runnung them to the jdm dizzy. does anyone know where they pin to on the jdm dizzy cuz the info i have found is verry vague. thanks
Old Sep 27, 2007 | 06:24 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">the sprocket has magnets as you call it marks, and it reads it as a pickup, kinda like the hall effect</TD></TR></TABLE>
Its magnetic pickup, halleffect uses little windows and displays a DC digital signal. Magnetic pickup sends an AC analog signal.
Old Oct 24, 2007 | 09:21 PM
thecaliskater's Avatar
can you tell me where the sprocket is? i have the exact same issue as ludatic 98...
Hondaciv95VX
Dec 28, 2020 10:46 AM
tuquikgsr
Nov 10, 2008 01:45 PM
mc_civic213
Jun 21, 2008 04:24 PM
98civichb
10
May 22, 2008 05:26 PM
live_again_integra
Nov 21, 2006 01:57 AM
