Cylinder tolerances
I am measuring my block so I know what size pistons to order. (F/H22 setup) and I'm just wonder what the out of round tolerances are. It look like some of the cylinders are as much as 4 ten-thousandths off towards the center. Is that an acceptable number?
also while also on this topic, I measure the block without a bore/hone plate as I don't have one and I'm about 99% sure my local shops do not have one for the F/H series. How much cylinder distortion is there and how many of you have had sucessful bore/hones without one? My block seems to be right at 85mm so I'm planning to just have it honed and use 85mm pistons
one last thing, does anyone have a link to the bearing color chart? Not just the colors and sizes, but the table that givs you the numbers and letters on the crank and block to give you the corresponding color, thanks. I lost my chart, and my reference bearings :/
Modified by Speedra500 at 12:21 PM 2/18/2007
hondaapi
Nov 10, 2006 09:29 AM
Apex i ITR
Aug 12, 2002 01:34 PM
