new problem with my B16
Old Feb 18, 2007 | 01:04 AM
b16nonoy's Avatar
Default new problem with my B16
it was working before..I decided to turn my car on and mess with the idle some more..
now my motor wont let me pass 4000rpms...it bogs like as if my rev. limiter is set at 4000rpms....wierd...wasnt like that 2 days ago when I was messing with the idle..i changed ECU's that didnt work...
Old Feb 18, 2007 | 05:26 AM
nonvtecD's Avatar
That's limp mode and you should be throwing a solid cel. Is it a chipped ecu?
Old Feb 18, 2007 | 09:08 AM
spun Vtec's Avatar
Default Re: (nonvtecD)
Try letting the ecu unplugged for a wile, check make sure all your plug wires are pushed in the whole way.
Codes?
Does the car run smooth when below 4k?
Old Feb 18, 2007 | 09:19 AM
EFvtec Yo!'s Avatar
When my dizzy went out in my B16 EF it wouldnt let me rev it over 4K. Check the codes and see if maybe it is throwing a distributor code.
Old Feb 18, 2007 | 09:25 AM
b16nonoy's Avatar
Default Re: (EFvtec Yo!)
my dizzy is brand new....the ecu is a chipped ecu...but it was all working 2days ago...untill I turned it on..I will double check my ecu codes though...
Old Feb 18, 2007 | 08:08 PM
nonvtecD's Avatar
If the chip is loose it will put you in limp mode. Something is up with your chip.
Old Feb 18, 2007 | 08:21 PM
LABjunkies's Avatar
Default Re: new problem with my B16 (b16nonoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">it was working before..I decided to turn my car on and mess with the idle some more..
now my motor wont let me pass 4000rpms...it bogs like as if my rev. limiter is set at 4000rpms....wierd...wasnt like that 2 days ago when I was messing with the idle..i changed ECU's that didnt work...</TD></TR></TABLE>
TRY CHECKING CODE FOR TDC IN DISTRIBUTOR AND TRY CHANGING THE CHIP MIGHT HAVE WENT BAD.
Old Feb 19, 2007 | 12:59 AM
b16nonoy's Avatar
well I have a fried chip..that is why I have this problem..
avinad
Jun 19, 2007 11:02 PM
punkracer
12
Nov 2, 2006 04:09 PM
siregcivic
Aug 20, 2005 02:39 AM
stillrockin18s
Jun 27, 2005 09:38 AM
CRseXy
Jun 19, 2005 04:41 PM
