Starter
Old Feb 17, 2007 | 08:37 PM
Haccord21's Avatar
Default Starter
My starter seems to be going out on my F20a. When i go to start the car it takes about 10 to 15 seconds to start. I use to think it was only because the car was cold but it turned out to happen even after the car had been driven around the town. Anyone know were i could get a new one or what i could do?
Old Feb 18, 2007 | 08:42 AM
hondadude's Avatar
Default Re: Starter (Haccord21)
Could you maybe explain the problem a little better?
Do you mean that you turn the key and it takes 10-15 seconds for the starter to start cranking the engine?
For schematic purposes could you say what year your Accord is? I promise no one here will laugh at you for having an older car.
Old Feb 18, 2007 | 02:51 PM
Haccord21's Avatar
Default Re: Starter (hondadude)
It takes about 10 to 15 seconds trying to crank over. Sometimes it trys cranking over then it just quits and i have to try over again but the second time it starts right up. I dont know why it does that. My car is a 93 lx sedan. Why are you asking for my year when your post says not to??
Old Feb 18, 2007 | 05:28 PM
JDM_DC4_Fanatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haccord21 &raquo;</TD></TR><TR><TD CLASS="quote">My car is a 93 lx sedan. Why are you asking for my year when your post says not to??</TD></TR></TABLE>
LMFAO!!! welcome to H-T...I can tell your gonna be a smart one!
Anyway, as for your problem. If the car is cranking over for a long time then starting, it may be a weak fuel pump. try cycling the key a few times before starting it. And by cycling the key, I mean, turn it from off to on a few times, without cranking it. This will prime the fuel pump, and will help build up fuel pressure. If you cycle the key 2-3 times, and it fires on the first crank, then you need a new fuel pump, or the fuel filter may be plugged.
try that, and then let us know what happened
Old Feb 18, 2007 | 07:17 PM
Haccord21's Avatar
Default Re: Starter (JDM_DC4_Fanatic)
Damn dude your smart. I turned the key not cranking it about 2 or 3 times then the third time i went to crank it and it started right up. Where can i get a fuel pump? What would cause the fuel pump to go out like that?
reeder5001
Jan 15, 2010 05:26 PM
everlight44
Feb 7, 2009 11:35 AM
pepper
Sep 21, 2007 07:27 PM
SalmanzCivic
Jan 4, 2005 09:14 PM
surfsup3841
Apr 11, 2002 08:37 PM
