Changing gear box oil...
Just was wondering if anyone can offer up some tips... I wanted to change the gear box oil, just had a few questions...
1. Torque specs on the two bolts.
2. What oil is best, I was told stick with Honda.
3. How much oil does the R gear box take.
4. Any good tricks on how to refill the tranny.
5. Any good websites that show the process.
Thanks in advance.
I did a search, did find too much info so I thought I would ask... so relax!
Thanks in advance.
1. same as oil pan
2. Honda MTF
3. 2.2-2.3 qts.
4. long hose and funnel
5. http://www.c-speedracing.com/howto/t...ransfluid.html
2. Honda MTF
3. 2.2-2.3 qts.
Thanks in advance.
Thanks in advance.
2- I just put B&G Synchroshift oil. Very good so far. Gear changes are very smooth.
3- You will need 2.3 litres. With the car leveled you should put oil until it starts to overflow out of the hole.
4- Use a flexible hose (about 1/2" in diam, 3 ft long) and a funnel. Put one end of the hose through the refill hole and the funnel at the other end.
Ditto!
Ditto!
1 qts = 0.946 litres.
So 2.3 qts= 2.17 litres.
I don't have my manual in front of me ( I am at work) but I am pretty sure it says 2.2 litres for the MT oil change alone and 2.3 litre for a complete MT ovehaul.
