B16a stoked with a b17 crank?
I just picked up a b17 crank/rods/pistons for my 00 civic si, I'm not interested in lowering my compression or r/s so using the b17 rods/pistons is out and i'm not ready to go with forged internals until i decide to bore and sleeve the block. Does anyone know what cr i'll get with the b17 crank with b16 rods/pistons? I would expect an increase but does anyone know by how much?
[Modified by Deltax75, 4:04 PM 5/20/2002]
YOU NEED TO USE THE B17A RODS.
You can dump the B17 pistons and use the B16A pistons though.
If you kept the stock B17A rods/pistons/crank and put these internals into your B16A block (aka stroking it), you're compression would be dropped to that of a B17A's compression ratio. Now if you used the B16A pistons from your Si block, your compression ratio would be about.. 10.5cr . So bumping up your stroke, 1 liter bumps up the compression .3 points, if you stick with your Si coupe's pistons (PR3 b16a piston).
Of course your compression ratio will change if you use a thinner headgasket, go wider diamter (oversize) piston, use a GSR/P72 head, or mill your b16a head..
If you went CTR pistons, your CR would be about 11.4.
