Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Check engine light
Old Feb 15, 2007 | 09:05 PM
jdmkid_82's Avatar
Default Check engine light
I have a 2005 civic DX sedan and it was throwing the codes for a bad Throttle poisition sensor (TPS) and a bad Primary o2 sensor.. I then replaced the whole throttle body and replaced the O2 sensor w/ a brand new one.. Then i had it checked again and it still through the code for the O2... I reseted the ECU by removing the fuse and all... what else could be wrong?..thanx
Old Feb 16, 2007 | 06:34 AM
Boilermaker1's Avatar
Check the plug and make sure the connection isnt loose.
Old Feb 16, 2007 | 08:59 PM
LowTec MOHawk's Avatar
Default Re: Check engine light (jdmkid_82)
first of all whats the code that your getting? cant tell u were to look with out knowing the code. secondly why did u automatically think that the 02 was bad?
Old Feb 16, 2007 | 09:14 PM
jdmkid_82's Avatar
Default Re: Check engine light (mikeformos03dx)
Cuz the codes i was getting were po135 (02 sensor) and the tps im not worried about now cuz thats fixed
Old Feb 17, 2007 | 12:10 PM
ok first off your car has an A/F sensor, and if you have replaced it then its probably not bad. the next place i would go to is the A/F sensor relay as well as check fuses 2 and 4 of the under dash fues/relay box. fuses 2 and 4 are the fuses for the load and control sides of the A/F relay. if the fuses are good then its probably the relay. if its not the fuses or the relay then its gonna get a bit tricky and youll need a voltmeter or DVOM. ill post up the rest of the diagnosis procedure if its not the relay or fuses. good luck bud
Old Feb 20, 2007 | 04:03 PM
jdmkid_82's Avatar
Old Feb 20, 2007 | 09:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkid_82 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE> does that mean u figured out the problem? haha
alpinegroove
30
Oct 13, 2013 12:55 PM
greyejcoupe
Oct 3, 2009 10:48 AM
pcorad
Jul 29, 2008 08:17 AM
vtec-adykt
Sep 12, 2005 01:09 PM
CaptainObvious
Jul 6, 2003 10:43 AM
