built b18b wont start need help!!!!!
Old Feb 15, 2007 | 05:42 PM
nylshatch's Avatar
Default built b18b wont start need help!!!!!
i have a built b18b and cant get it to start. im getting spark but no fuel. i jump the fuel pump out and get 40 psi at my gauge but the injectors arent spraying. ive already changed the main relay under the dash and the module in the distributor. i really need help i need it to run
Old Feb 16, 2007 | 12:34 AM
ImportMotorSpec's Avatar
Default Re: built b18b wont start need help!!!!! (nylshatch)
Are the injectors new?
I have had injectors "stick" to where i have had to push the little needle on the end with a pick tool. They will only move the slightest bit. It is hard to feel but you can feel them move a bit.
This is mainly on JDM motors that have been sitting for a while though.
Old Feb 16, 2007 | 07:34 AM
Bakeoff's Avatar
what are you running for an ecu?
Old Feb 16, 2007 | 02:18 PM
nylshatch's Avatar
Default Re: (Bakeoff)
the injectors were my old ones and i also tried a set from a running car and i think its a chipped po6 from phearible.net i also tried my stock ecu too. the injectors are grounding out but not gettin power
Old Feb 16, 2007 | 06:10 PM
nylshatch's Avatar
Default Re: (nylshatch)
come on guys i really need some help here!!!!
Old Feb 21, 2007 | 10:37 PM
camboMONK's Avatar
Are you getting fuel to the feul rail but not to the injectors? if so, it's probably your wiring. I had the same problem. Pin out each injector wire to the ecu.
SIR_DREAM_KID
Feb 22, 2012 05:26 AM
SpoonCivicSir20
12
Sep 19, 2009 07:26 AM
BbOi0420
May 29, 2005 03:21 PM
jesse d
Aug 6, 2004 06:19 PM
crxguy05sir
May 30, 2003 08:02 PM
