What does it feel like when your syncos are going in any of your gears?
Old May 20, 2002 | 03:06 AM
hooptie157's Avatar
Default What does it feel like when your syncos are going in any of your gears?
Is is like a grinding sensation and its kinda hard to put in gear because to feel something spining in front of the gear everytime you try and put it in?? If not what the hell does it feel like , because my third gear may have had it
Old May 20, 2002 | 05:05 AM
EagleR's Avatar
Default Re: What does it feel like when your syncos are going in any of your gears? (hooptie157)
The easiest way to tell is that the gear will grind when you put it in. It starts off only doing it when you partialy clutch or clutch fast at high RPM. Then it will do it at full clutch RPM unless you give the syncro a LONG time to spin up, and it gets progressivley worse. You can force it into gear even when it grinds, but this is bad (obviously) for youre gear set. Usually third gear goes first. Then Fifth. Hope this helped.
Jody-whos third and fifth syncros are all but gone
Old May 20, 2002 | 05:11 AM
hooptie157's Avatar
Default Re: What does it feel like when your syncos are going in any of your gears? (EagleR)
OH god noooo, its my third gear that feels funny, Damnit!!! Is this covered by the warrenty?? (P.S. I have an exedy clutch, flywheel, and ATS final but they don't know about them).
Old May 20, 2002 | 05:12 AM
austrian type-R's Avatar
Many people have syncro problems on their R's, I wonder why. Are they so weak? 2 years ago my 4th syncro was fucked up, now it is my 3rd too. But only when shifting quick above 8000rpm.
Old May 20, 2002 | 06:11 AM
AssPenny's Avatar
Default Re: What does it feel like when your syncos are going in any of your gears? (austrian type-R)
I was told by the dealer that they could not touch my tranny due to my ATS FD. They knew I had it by taking the car out and checking the RPM to speed
Old May 20, 2002 | 06:15 AM
hooptie157's Avatar
Default Re: What does it feel like when your syncos are going in any of your gears? (AssPenny)
they drove my car and didn't Notice it (yet). If they don't notice while they are driving will they be able to see it visually if they open up the tranny. Is it that visable?
Old May 20, 2002 | 06:17 AM
AssPenny's Avatar
Its not realy visabile in the tranny unless they count the teeth. However, they might notice that you did some work on it before they even open it up. Naples acura knew I droped the tranny the minute they put it up on the lift. All depends on the dealership.
Old May 20, 2002 | 06:50 AM
01ITR#700's Avatar
I get a very slight, slight grind on the 4-3 downshift occassionally only on real quick downshifts. I have verified that the clutch is fully compressed etc. Is that a possible synchro issue? It only happens occassionally and never happens on the 2-3 upshift.
Thanks.
M
Old May 20, 2002 | 07:26 AM
Renegade's Avatar
Default Re: What does it feel like when your syncos are going in any of your gears? (01ITR#700)
cool avatar
Don't have much to say on the synchro but noticed the avatar
Old May 20, 2002 | 07:29 AM
hooptie157's Avatar
Default Re: What does it feel like when your syncos are going in any of your gears? (98401R)
who's avatur??
Old May 20, 2002 | 07:31 AM
Renegade's Avatar
01ITR#700
gabe768
Jun 7, 2010 03:06 PM
ap1_driver
Honda S2000
12
Jun 18, 2006 02:14 AM
91SiRX
Jul 26, 2005 04:17 PM
S10RALLYRACER
Oct 13, 2004 05:16 PM
Austin
Dec 1, 2003 12:04 PM
