sir codes
Old May 20, 2002 | 01:44 AM
ef civic's Avatar
Default sir codes
i have a first gen b16a cable and my problem is when the vtec kicks in the car lags and threw a code 12. i was wondering if the jdm codes are the same as usdm. and if anyone has a opinoin on why is lags your help will be greatful appreciated thanks
Old May 20, 2002 | 12:08 PM
Perfectionist's Avatar
Default Re: sir codes (ef civic)
I doubt JDM and USDM codes would differ. As you probably know, the code 12 is the EGR system. A faulty EGR system could very well cause a lag.
Old May 20, 2002 | 01:29 PM
spettinger's Avatar
Default Re: sir codes (Perfectionist)
i didn't think B16's had an EGR system. check your knock sensor.
Old May 20, 2002 | 03:53 PM
RexB16's Avatar
Default Re: sir codes (wreckedhatch)
auto b16s did
Old May 20, 2002 | 09:00 PM
ef civic's Avatar
Default Re: sir codes (RexB16)
anyone else got a clue ... info i have a jg head ported on intake and exhaust dc header jg throttle body but no injectors and stock civic fuel pump could i be detenating????????
Old May 21, 2002 | 08:43 AM
ghettochild's Avatar
if its giving you code 12 and that is egr valve just take your egr valve of and youll need to clean the little shaft thing. it should be free moving get all the crap off of it and make sure it moves freely. if it was your knock senser it would throw code 23 or 22 or 21. so do that to your egr valve and if that doesnt work tell me and ill give you one because i have a couple.
technine
Apr 18, 2007 10:51 AM
ED9man
Jun 18, 2006 05:43 AM
AccordRacing
May 26, 2005 07:06 PM
diewX3
Jan 26, 2005 09:22 AM
ef civic
May 21, 2002 02:13 PM
