Honda S2000 Honda S2000
2 quick q's about the Cusco cage...tried search but can't find anything
Old Feb 15, 2007 | 11:09 AM
LVCURVS's Avatar
Default 2 quick q's about the Cusco cage...tried search but can't find anything
I was looking at thier (cusco/safety 21) 7 pt setup and it seems that the driver, with a helmet, would be REAL close to the cage.
Now, i'm small 5'7", 155 lbs soaking wet, but it still seems real close. I also read that there is a helmet cut out but it is on the right hand side of the halo for RHD vehicles.
My question is do they make a cage for the LHD cars or is thier enough head room to use the stock seats w/ a helmet and a padding around the bar with out smacking the halo?
My other question is why do all the picts i see of this cage in the cars have no padding? it may look good but i don't feel like hitting that thing plus i would think you would need that padding to pass even a track day event.
Just curious. thanx guys!
Old Feb 15, 2007 | 12:26 PM
SuzukaBlueAP2's Avatar
Default Re: 2 quick q's about the Cusco cage...tried search but can't find anything (LVCURVS)
If you search around on here you'll probably find that most of the folks here think Cusco is nothing but bling.
If you truly want a cage, personally, I wouldn't suggest daily driving with it.
And for competition use I don't believe it meets the safety specs of most organizations out there.
I'm not sure off the top of my head who else offers a cage for the S...but a quick Google might help...
Old Feb 15, 2007 | 12:32 PM
Mr. Projekt's Avatar
* B A N N E D *
The padding would bring it even closer to your head.
If you're serious about competition, get a weld in made specifically for your car, stature, and racing goals. I'm assuming you are since you're asking about a 7pt.
Old Feb 15, 2007 | 12:47 PM
LVCURVS's Avatar
Default Re: 2 quick q's about the Cusco cage...tried search but can't find anything (Mr. Projekt)
I brought up the 7pt because on bulletproof automotive's site, the 7pt picture is the only one you can clearly see what i'm talking about.
yeah, the padding would bring it closer but i wasn't sure if with it there still would be enough room. If it's just bling, then not worth my money. Not really into spending money on stuff that doesn't work especially if i depend on it to keep myself from getting hurt.
Honestly, i just want a little more protection then the stock hoops but with the option to add on later.
I plan on getting heavy into the track days at the moment not full race just yet and i honestly can't afford a hardtop to fit most of the other bars.
I guess i would probably have to go custom to get what i'm looking for? any suggestions?
Old Feb 15, 2007 | 12:55 PM
* B A N N E D *
Spoon/Mugen 7pt rigid cage (no bolt joints) seem to be a better choice. I've done the install on a 7pt cusco and you have to get the drill spots on point or else the cage will fit like ****. A weld in wouldn't cost THAT MUCH more than the Mugen/Spoon pieces; the prices may even be comparable. Look into a weld in 4/6pt.
Old Feb 15, 2007 | 07:17 PM
Scott2000's Avatar
The Cusco cage looks pretty, but I wouldn't want to be in the car if it rolled over or was involved in a serious crash...
Old Feb 15, 2007 | 07:34 PM
Mr. Lucky's Avatar
Default Re: (Scott2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott2000 &raquo;</TD></TR><TR><TD CLASS="quote">The Cusco cage looks pretty, but I wouldn't want to be in the car if it rolled over or was involved in a serious crash...</TD></TR></TABLE>
those speculations have been said many times. has anyone ever experienced or seen a cusco cage fold in?
i've seen a hatch rolled over and so to speak bling cusco cage actually saved his roof from folding in. if he had a 6 point it probably would've killed him due to no helmet.
what i'm basically trying to say is, either way you're bound to get hurt if the S flips.
mr. lucky's back... sorry
Old Feb 15, 2007 | 08:33 PM
LAS2K's Avatar
Default Re: (Mr. Lucky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Lucky &raquo;</TD></TR><TR><TD CLASS="quote">
mr. lucky's back... sorry</TD></TR></TABLE>
where the hell have you been???
Old Feb 15, 2007 | 10:07 PM
Mr. Lucky's Avatar
Default Re: (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">where the hell have you been???</TD></TR></TABLE>
stacking my money lay low and chill...
been working a lot. got a new management from the client i work for. things are getting hectic.
Old Feb 16, 2007 | 02:21 AM
S2SLOW's Avatar
This is true the damn cage is made of chromoly its not going to move that much in a flip... But in the S its so close to you and thats what increases your chances of getting hurt
Old Feb 16, 2007 | 10:06 AM
S2Kintgen's Avatar
I had asked the question a while ago and from what everyone has told me, go with a weld in. Spoon, Mugen, Safety 21, cusco, all the same with their bolted joints. You are deffinatly going to want to go with a weld in.
Im still looking around for a good place to do mine. any suggestions??
Old Feb 20, 2007 | 04:51 AM
LVCURVS's Avatar
Ok, so since i'll pretty much be going custom weld in now, untill i get the money for that, can i run a set of harness's with the stock hoops? if so, how you guys doing it? is it just a bar that would be welded in between the hoops and i'd wrap the belts around the bar or would i have to go through the metal and install the hooks and reinforcements then clip the belts to that?
Old Feb 20, 2007 | 05:15 AM
RacerXI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVCURVS &raquo;</TD></TR><TR><TD CLASS="quote"> Ok, so since i'll pretty much be going custom weld in now, untill i get the money for that, can i run a set of harness's with the stock hoops? if so, how you guys doing it? is it just a bar that would be welded in between the hoops and i'd wrap the belts around the bar or would i have to go through the metal and install the hooks and reinforcements then clip the belts to that?
No
Old Feb 20, 2007 | 05:28 AM
LVCURVS's Avatar
Default Re: 2 quick q's about the Cusco cage...tried search but can't find anything (RacerXI)
No.......a lil more info as to why not please... can't be done with out cage? not safe?...all of the above?....no being a smart *** just trying to learn and figure this out
edit: nevermind......just saw a post below this one that talks about the 4pt harnesses...
back to the roll bar. somethign along this line is what i want... sorry, i'm at work and it won't let me click the add picture button.it's the spoon 4 point hoop.
http://www.autoanimal.com/imag...4.gif
Modified by LVCURVS at 9:40 AM 2/20/2007
Old Feb 20, 2007 | 05:55 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
if not going all out ***** to the wall why bother with the cage? there are many many die hards running their S without anything of with just a 4pt.
Old Feb 20, 2007 | 06:10 AM
blues2k3's Avatar
Default Re: 2 quick q's about the Cusco cage...tried search but can't find anything (S@nt0s)
going ***** out....
Old Feb 20, 2007 | 06:15 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 2 quick q's about the Cusco cage...tried search but can't find anything (blues2k3)
DRAG... and they say u shouldnt DRAG a S.. i LOVE it...
now thats serious bizz right there...... 140+mph car there...
Old Feb 20, 2007 | 07:17 AM
LVCURVS's Avatar
right, which is why i put that link there, it's a pict of the spoon 4 pt bar. and those inline s2's are wicked.
Old Feb 20, 2007 | 07:21 AM
Delano5050's Avatar
You can go with the Bitterman Roll bar or the ELDA enginering bar. Both are good quality and meet's (Some) competition requirements.
Old Feb 20, 2007 | 07:27 AM
Delano5050's Avatar
Default Re: (Delano5050)
http://www.s2ki.com/forums/ind...31242
It's an old post but here is what the Bitterman Bar looks like.
PPLH8R
Welding / Fabrication
Feb 4, 2009 06:42 PM
SuperTuner12010
Nov 28, 2008 09:29 AM
LVCURVS
May 9, 2007 05:11 PM
bomber
Sep 13, 2004 10:18 AM
IGGY
Jun 22, 2002 03:28 PM
