car won't start anymore.. help needed
Old Feb 15, 2007 | 08:12 AM
huepowered's Avatar
Default car won't start anymore.. help needed
well today was a crappy day.
i got stuck at the end of my driveway backing out over the snow/ice storm we had yesterday. while spinning my tires in reverse, i stalled and my car would not start back up. i left my car blocking one lane on a busy street.
the motor cranks, i have fuel. i don't have a compression checker but i'll get one as soon as i get another car here to use. any ideas what could be the problem?
let me know if u need anymore info.
Old Feb 15, 2007 | 11:01 AM
GsrIntegra789's Avatar
Default Re: car won't start anymore.. help needed (huepowered)
try checking for spark first. then worry about compression
Old Feb 15, 2007 | 11:03 AM
Preferio's Avatar
Default Re: car won't start anymore.. help needed (GsrIntegra789)
Timing belt perhaps? Checked it yet?
Old Feb 15, 2007 | 11:05 AM
Default Re: car won't start anymore.. help needed (PreFerio)
my guess would be, either his coil went or his ignitors went. has happened to me and my friend before
Old Feb 15, 2007 | 11:09 AM
Preferio's Avatar
I highly doubt it's the coil, but maybe the module.
Old Feb 15, 2007 | 11:36 AM
huepowered's Avatar
checked the compression 180 across the board (i assume this also means my belts are good). how do i check for spark? what's the "Module" you speak of?
Old Feb 15, 2007 | 11:43 AM
Preferio's Avatar
That's the ignition module, or otherwise referred to as an ignitor. They are in the distributor and are rather easy to change.
Old Feb 15, 2007 | 12:11 PM
Old Feb 15, 2007 | 12:49 PM
kikwear002's Avatar
coils like to go alot in hondas i have noticed.
but you can check for spark by unplugging cylinder # 1 from the spark plug, then stick any soark pllug in the wire and stick the plug next to a piece of grounded metal and have someone turn the car over. DO NOT TOUCH the wire, plug, or metal when doing this it will shock you. It doesnt hurt that bad although.
When the engine is turning over you should see it sparking.
I would also dissconnect the injectors so the car does not start, and load the cylinders up with fuel.
Old Feb 20, 2007 | 12:13 PM
huepowered's Avatar
Default Re: (kikwear002)
Problem solved. Bad ignition coil. I replaced the cap and rotor while I was at it, now it runs even better than before it broke.. haha
LMdb2teggy
May 24, 2010 12:29 PM
kelviiv
Dec 17, 2008 11:19 AM
NipponRacing
33
Apr 12, 2007 04:35 PM
geezer06
Nov 17, 2003 07:31 PM
aVstAr
Jan 21, 2003 06:24 AM
