99 motor (OBD2) into 94 chasis (OBD1). Need Help
Old Feb 14, 2007 | 11:09 PM
StReCh4130's Avatar
Default 99 motor (OBD2) into 94 chasis (OBD1). Need Help
ok, I have a 94 Integra LS and I blew the motor. I found a pretty good deal on a 99 GSR motor, except I was told I'm gonna be running into a few problems considering my car's an OBD1 and the motor's an OBD2. Now, I need advice on what exactly the problems are and how I can get around them. Please Help.
Thanks
Old Feb 14, 2007 | 11:23 PM
GoldCoin's Avatar
Default Re: 99 motor (OBD2) into 94 chasis (OBD1). Need Help (StReCh4130)
some of the sensors. ecu jumper obd2>obd1 , vtec wiring. i think that is the major ones.
Old Feb 14, 2007 | 11:59 PM
StReCh4130's Avatar
Default Re: 99 motor (DC TWOin IT)
alright, thanks by the way... but what sensors exactly and how can i get around that? Also, how can I get the ECU to work?
Old Feb 15, 2007 | 12:33 AM
GoldCoin's Avatar
Default Re: 99 motor (StReCh4130)
nvm on the sensors. im pretty sure you need a obd1 harness ,obd1 ecy for sure, obd1 distibutor and it should be good.
Old Feb 15, 2007 | 05:14 AM
kikwear002's Avatar
You will need an obd 1 map sensor becuase although the plug is the same the wires are backwards.
Also you will need an obd 1 distruibutor. The problem with that is it will not bolt up to an obd 2 head. So you can swap the internals from the obd 1 dizzy to the obd 2 dizzy and bolt it up and be done.
Done use an obd 1 dizzy and cut an ear off like every other half *** out there.
Then you will need the obd 2 .obd 1 conversion adapter harness. Then get a chipped p28 or an obd 1 gsr computer.
760dc4
Jun 19, 2009 09:20 AM
soon2bdropped
Aug 30, 2007 10:32 AM
A-TL
Jan 22, 2006 01:14 PM
MidwestSi
Sep 13, 2004 09:24 AM
TKL
May 27, 2003 07:57 PM
