problem with corner lamps
Old Feb 14, 2007 | 05:11 PM
oem_CD5's Avatar
Default problem with corner lamps
alright, i don't know what happened but, all of a sudden, my corner lamps do not work. that is, the lamps on the side of the headlights. this problem also includes all of the lighting that is supposed to come on when you turn the tab that is on the stick on the steering column (corner lamps, rear lights, and speedometer lights). none of that comes on, but my headlights still work when i turn them on. any suggestions on what the problem might be?
Old Feb 14, 2007 | 07:02 PM
hondadude's Avatar
Default Re: problem with corner lamps (oem_CD5)
I'd say to first check the fuses; then with a schematic you could check the wires from the back of the light switch to see if it is putting thru power.
year and model is needed to find the schematic, check my signature link
Old Feb 15, 2007 | 06:54 PM
oem_CD5's Avatar
Default Re: problem with corner lamps (hondadude)
is the fuse by the pedals? and how would you check the fuse?
Old Feb 15, 2007 | 07:06 PM
hondadude's Avatar
I can't pull up the schematic for your car without knowing the Year & Model.
might be underhood fuse box? ?
you can test the fuses with a test light or visually check them for the center "wire" to be burnt out
Old Feb 16, 2007 | 04:52 PM
oem_CD5's Avatar
it's a 94 accord dx non-abs
wakenbake215
Honda Civic (2006 - 2015)
Feb 8, 2012 07:45 AM
Seedless DC2
Aug 20, 2009 05:41 AM
guy_that_owns_3_Rex's
May 11, 2004 01:53 PM
djtony5
Mar 31, 2003 01:18 PM
shattergsr
Nov 25, 2002 11:36 AM
