Integra Failed Smog Today, someone help
Old Feb 14, 2007 | 04:45 PM
honda genome
Guest
Posts: n/a
Default Integra Failed Smog Today, someone help
1995 integra RS (California)
miles 151k
Here are the results, I failed only the %CO everything else passed fine:
Someone please help me and tell me what this means, and what I should do, any help would be appreciated, thanks
15mph
%co2: 14 %O2: 0 HC: max = 90 ave=21 meas=48 %CO: max =0.54 AVE=0.06 MEAS= 1.18 (<---FAILED) NO: Max=711 AVE=150 Meas=51 (very low)
25mph
%co2: 14 %O2: 0 HC: max = 56 ave=13 meas=40 %CO: max =0.53 AVE=0.05 MEAS= 0.93 (<---FAILED) NO: Max=754 AVE=136 Meas=38 (very low)
Old Feb 14, 2007 | 06:30 PM
honda genome
Guest
Posts: n/a
anyone...?
Old Feb 14, 2007 | 06:42 PM
erik92DA's Avatar
Default Re: (Honda Genome)
Looks like the engine is running rich for some reason. Or the cat is losing its efficiency. Probably not ignition related.
Old Feb 15, 2007 | 08:54 AM
honda genome
Guest
Posts: n/a
Yea, that's what some people have been telling me, there is too much fuel in the engine which isn't getting combusted, therefore having a spike in CO (running rich). Could be a number of problems...clogged cat, which will send wrong signal to MAP thus making the car use more gas. Maybe O2 are starting to go bad....
Old Feb 15, 2007 | 10:20 AM
SlammedDC2teg's Avatar
Was your car warmed up. I had a broken thermostat and almost failed in the same spots as you did.
Old Feb 16, 2007 | 05:00 PM
honda genome
Guest
Posts: n/a
CEL came on today, faulty O2 sensor.....changed O2 sensor also, will post results in the morning if I pass smog or not.
Old Feb 16, 2007 | 05:10 PM
DC2_005200's Avatar
Yea hopefully it was just your o2 that went out.
Old Feb 16, 2007 | 05:34 PM
youre_scum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Genome &raquo;</TD></TR><TR><TD CLASS="quote"> Could be a number of problems...clogged cat, which will send wrong signal to MAP thus making the car use more gas. Maybe O2 are starting to go bad....</TD></TR></TABLE>
but i thought the primary o2 sensor determined the feul map, the secondary on the o2 is there to make sure all unburned gas is burned thru the cat? Cause a catalyzer is supposed to burn all enviromentally harmful unburned gases right? So either your catalyzer is on its way out, on something air fuel related is dirty. You should move to north georiga, us rednecks aint got no emersions.
Old Feb 16, 2007 | 05:38 PM
youre_scum's Avatar
Default Re: (youre_scum)
also, factory o2 sensors can only read voltage signals between a very small margin or band, then fail below and above it, its usaually like 9v to 13v???(hints a WIDEBAND o2 senosr being very vaulable to tuning) or something very small, any way make sure it really is a pricey o2 sensor before replacing it.
Old Feb 16, 2007 | 05:40 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youre_scum &raquo;</TD></TR><TR><TD CLASS="quote">
he only has one O2 sensor, he is OBD1
Old Feb 16, 2007 | 05:49 PM
youre_scum's Avatar
Default Re: (Wayne_Curr)
so it only has a primary o2 sensor at the end of the collectors, then how would your ecu know wether or not the cats bad?
Old Feb 16, 2007 | 05:51 PM
youre_scum's Avatar
assuming your gas milage hasnt dropped, id say its just the cat not burning unburned fuel.
Old Feb 16, 2007 | 09:12 PM
honda genome
Guest
Posts: n/a
CEL came up as O2 sensor...Obd1 has only 1 o2 sensor b4 cat....
Old Feb 17, 2007 | 08:55 AM
honda genome
Guest
Posts: n/a
O2 sensor was the culprit....car passed smog 20mins ago!!!!
Ran4it2
May 8, 2008 03:29 PM
ek-g6
Sep 14, 2007 01:39 PM
bmxer
Jul 10, 2007 09:18 PM
kenny7
May 11, 2007 09:13 AM
nos4a2si
Jul 3, 2005 09:42 AM
