Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Presure Washer
Old Feb 14, 2007 | 03:11 PM
xanatos's Avatar
Default Presure Washer
Hey guys i was wondering if i should use my pressure washer to clean the engine bay? do you guys think it would damage any wiring or sensors?? thanks in advance!
Old Feb 14, 2007 | 03:54 PM
Hellzcivic's Avatar
Default Re: Presure Washer (xanatos)
DANGER, DANGER WILL ROBINSON.
I suggest you do no use a pressure washer on the engine bay.
The one and only time I ever did this (on my first Honda - 86 Civic SI), it took me a week to get the car running again. Sucker blew off hoses and wires I did not know I even had. Although the electronics under the hood are "water tight", water under pressure might still sneak in, and as we all know, water and electricity do not mix.
I suggest you use the painstaking method of a damp rag and canned air.
Just a suggestion.
Old Feb 14, 2007 | 04:04 PM
xanatos's Avatar
Default Re: Presure Washer (Hellzcivic)
thanks for the input, I've seen kits that will clean the engine bay on some auto parts store i will use of one those instead
Old Feb 14, 2007 | 05:10 PM
Nohawk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xanatos &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input, I've seen kits that will clean the engine bay on some auto parts store i will use of one those instead </TD></TR></TABLE>
Man, I would also watch out about using it on your car paint. Too close and it will damage the paint coat. Or at least that has been my experience.
Old Feb 14, 2007 | 06:01 PM
originalg00kster's Avatar
Default Re: Presure Washer (Si 4 Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si 4 Life &raquo;</TD></TR><TR><TD CLASS="quote">
Man, I would also watch out about using it on your car paint. Too close and it will damage the paint coat. Or at least that has been my experience.</TD></TR></TABLE>
he's right...use the right nozzel. or just stand back a feet or 2.
Old Feb 14, 2007 | 06:28 PM
WILD_WILL's Avatar
Default Re: Presure Washer (originalg00kster)
I watched my cousin power wash the motor in his NHBP type r when i was 16 it was a painful thing 2 watch lol but he didnt damaged nothing i wouldn't rec it tho.
gus738's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellzcivic &raquo;</TD></TR><TR><TD CLASS="quote">DANGER, DANGER WILL ROBINSON.
Just a suggestion.</TD></TR></TABLE>
not nessary on this 06 civic , cars / trucks that were made i belive from 90 til now are protected (old cars have no wires covers or stuff like that, that makes it exposed and damging from water.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xanatos &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input, I've seen kits that will clean the engine bay on some auto parts store i will use of one those instead </TD></TR></TABLE> thats a good ideal
so i never used the pressured water but you can use a simple hose , see this is my ideal ,
water &gt; AIR CONPRESSOR = clean
so if even if water damges car as long as you dry the **** out of it your golden....
so if you dont have air conpressor and are consern about a possible water damge then use the cans from auto zone and please fellow directions....
but im almost 100 % sure no harm can come into new cars they are pretty coverd up
Old Feb 14, 2007 | 06:29 PM
TRE_'s Avatar
I've always pressure washed the **** out of my engine bay(s) and never had any problems... just dont completley soak the fuse box, etc.
Old Feb 14, 2007 | 06:58 PM
eL's Avatar
eL
I've done this on my FG and as long as you use the correct nozzle with the right amount of pressure you should be fine.
Old Feb 14, 2007 | 07:19 PM
liquidmetal's Avatar
i used to detail cars, i would but degreaser in the engine bay and spray them off all the time.. you just to be carefull and not soak the fuse box, spark plugs... etc.. just do it smart and you will be fine.. i power wash mine all the time
Old Feb 14, 2007 | 07:28 PM
pd0019's Avatar
Default Re: (liquidmetal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquidmetal &raquo;</TD></TR><TR><TD CLASS="quote">i used to detail cars, i would but degreaser in the engine bay and spray them off all the time.. you just to be carefull and not soak the fuse box, spark plugs... etc.. just do it smart and you will be fine.. i power wash mine all the time </TD></TR></TABLE>
^ what he said.
i worked w/ a honda mechanic and we always cleaned all hondas w/ a pressure washer and degreaser. never had any problems. just dont put the nozzle right up to the motor, theres no need for that.
Old Feb 14, 2007 | 08:21 PM
xanatos's Avatar
Default Re: (pd0019)
SWEET! thanks everyone, i will make sure i will use the delicate nozzle and the degreaser and i will make sure to keep my distance from then engine. i guess it's just common sense you must use right?
Old Feb 15, 2007 | 05:41 AM
IT GUY's Avatar
Default Re: (xanatos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pd0019 &raquo;</TD></TR><TR><TD CLASS="quote">
^ what he said.
i worked w/ a honda mechanic and we always cleaned all hondas w/ a pressure washer and degreaser. never had any problems. just dont put the nozzle right up to the motor, theres no need for that.</TD></TR></TABLE>
Yeah, always used a pressure washer on all my cars engine bays over the years. It's all about the tip and the distance. We have one that we use for concrete demolition (no **** it really does break up concrete). On the same 5 hp Honda pressure washer, I can swap the nozzle out and use it to wash the dog (theoretically since I don't have a dog)
Old Feb 15, 2007 | 06:21 AM
TRE_'s Avatar
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
It's all about the tip and the distance. </TD></TR></TABLE>
Quoted for truth.
Old Feb 15, 2007 | 12:40 PM
japspecjohn's Avatar
Default Re: (TRE_)
Id do it while the cars running!
Old Feb 15, 2007 | 12:42 PM
Hellzcivic's Avatar
This is great info. I have been too scared to pressure wash an engine since my little nightmare. I have 96 24' Jamboree Searcher (RV), that desperately needs a power wash in the engine bay. I will try out the suggestion in the thread.
Thanks for straighten me out on this.
Old Feb 15, 2007 | 12:44 PM
gus738's Avatar
you could just hose it down with a non pressured then if its not enough use a pressure , do you have air conrpessor? if so great wet the car dry it out
Old Feb 15, 2007 | 02:13 PM
808k20z3's Avatar
Default Re: Presure Washer (gus738)
use a wide spread nozel and you'll be fine!i work at a toyota dealer we do it to every car that comes in. works like a charm. and its so easy just watch out for the intake if u have a SRI cold air u sould be fine. mine gets this treatment every month or so and i gotta say it looks brand spanking new yet!plus my car says he loves it!
Old Feb 15, 2007 | 02:18 PM
xanatos's Avatar
Default Re: Presure Washer (808k20z3)
Hahaha cool, the pressure that i have is a craftsman, ill take some pics of it once im done, till the weekend that is!
Unseen Racer
10
Dec 10, 2008 03:15 PM
JJeg67
35
Dec 3, 2007 07:19 AM
Boots
Dec 20, 2006 08:09 PM
xiLLtegRax
Sep 15, 2004 08:12 PM
