car is making funny rattling sound just above idle...help!
Old May 19, 2002 | 08:36 PM
roman420's Avatar
Default car is making funny rattling sound just above idle...help!
ok i have a '91 integra LS with an automatic transmission and a b18a1.
yesterday i started hearing some kind of rattling noise coming from the engine area when the car is in drive or reverse, just above idle. it doesn't happen in neutral or park...only when the engine is under a load. the car vibrates a little at idle when there is a load on the engine which i know is pretty normal of a 4-cyllinder with almost 100k miles....but i can't figure out if the noise is possibly my transmission, or just something under the hood that's loose. i can only hear the rattle inside the car, when the windows are up and the doors are closed. and like i said it's most audible between 800-1100rpm's when the engine is under a load. the car has 98k miles and drives normally otherwise. possibilities that came to mind for me are either motor mounts, auto tranny slushbox startin to kick it, or something in the dash rattling. i don't think it's necessary to take it in to diagnose it unless it's possibly the start of a big problem since i plan on doing a swap within the next year anyway. any information is much appreciated...
-andrew
Old May 19, 2002 | 11:30 PM
roman420's Avatar
Default Re: car is making funny rattling sound just above idle...help! (roman420)
ttt
Old May 20, 2002 | 05:29 AM
88_SC_CRX_Si's Avatar
New User
Could be a heat sheild... Their are pretty bad about rattling in the lower RPM ranges.
Old May 20, 2002 | 07:13 AM
Prelude Vtec 23's Avatar
Default Re: car is making funny rattling sound just above idle...help! (88_SC_CRX_Si)
Do you have an aftermarket exhaust? If so, then it is prob the heat shield, you might want to check that out.
Old May 20, 2002 | 08:00 PM
roman420's Avatar
Default Re: car is making funny rattling sound just above idle...help! (Prelude Vtec 23)
nope stock exhaust. i do have an aem cold air intake but it's not that...it was the 1st thing i checked. i guess the heat shield thing is possible. its no big deal really cuz the car works fine i just hate funny noises if i don't know what they are ya know? hehe
if anyone has heard a similar sound on their car, let me know if u ever found it and what it is i'd appreciate it.
thanx,
drew
[Modified by roman420, 12:03 AM 5/21/2002]
Old May 23, 2002 | 11:06 PM
kkim's Avatar
try putting it in gear with the hand brake on and your foot on the brake. raise the rpm's to the the level that the rattling is at. have someone move about outside the car to pinpoint the souirce of the noise. that's how I found a rattle in the muffler that would only come out when the the car was in gear and under load. good luck. let us know what it was.
Old May 24, 2002 | 02:49 AM
GruvyTune's Avatar
New User
just went through this with my car. was the exhaust manifold bolts that were loose and gave a shuddering rattle at about 2200rpm especially when letting off the throttle after blipping it.
Old May 24, 2002 | 03:58 AM
IIIISTUMBLESIIII's Avatar
Hey i have a 94 civic and it did the same thing what kinda tires do you have on it if you have radial get them rotated becuase that what i had and i had to get them rotated i held off my driving test it sucked too!! yeh just get ur tires rotate oh another thing is the breaks
Old May 24, 2002 | 10:30 AM
roman420's Avatar
thanks so much y'all. i've isolated the noise to either an exhaust heat shield or the catalytic converter. now i gotta fix it lol
much appreciated,
-drew
norcali707
Honda Civic (2001 - 2005)
Dec 13, 2012 11:55 AM
wnk5190
Aug 25, 2008 07:55 PM
g2tegsown
May 14, 2005 06:11 AM
reignofchaos
Nov 10, 2003 02:14 PM
