Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
anybody use them...........longacre racing products?
Old Feb 14, 2007 | 11:00 AM
ekim952522000's Avatar
Default anybody use them...........longacre racing products?
Anybody ever use this gauge setup? It's one of the last things I need for my car and I'm trying to decide on gauges.
How are there products? Cheap or nicely made?
http://www.longacreracing.com/...4.jpg
I would like to eliminate the stock cluster and just run a tach and these gauges.
Old Feb 14, 2007 | 11:56 AM
WWDTrackRacer's Avatar
New User
Default Racepak dash?
Thought about this instead?
Racepak UDX Street Dash pn 250-ds-udxsr
"It is provided with everything required to display engine RPM, water tempera*ture, oil temperature, oil pressure, and battery voltage."
"By using the electronic speed sensor sending unit on your transmission it will also provide speedometer, odometer, and trip odometer functionality"
http://race.adv100.com/race/ar...96519
http://www.msdignition.com/med...y.jpg (large pic)
I'm thinking of getting one.
Old Feb 14, 2007 | 12:56 PM
junkyard racer's Avatar
Default Re: Racepak dash? (WWDTrackRacer)
dam, any idea of the cost of that?
I have been looking at this.
http://www.powertraincontrolso....html
the D200. Somewhere around $650- complete with datalogging...every gauge you would want/need...all touch screen...
Old Feb 14, 2007 | 01:00 PM
SoloSol's Avatar
I missed the price on the racepak digital dash. If its less than $500-$600 it might be worth it. I dont care for that D200 dash. It looks like the t-stat in my house.
Old Feb 14, 2007 | 01:04 PM
Ekasey's Avatar
Default Re: anybody use them...........longacre racing products? (ekim952522000)
I would highly recommend SPA techniques digital guages and displays.
http://www.spatechnique.com
Old Feb 14, 2007 | 01:07 PM
slammed_93_hatch's Avatar
Default Re: anybody use them...........longacre racing products? (Ekasey)
i use and really like the AIM products, http://www.aimsports.com/ ,
Great pricing for what you get. All the inputs you would want, shift lights, gear indicator, and data loging.
Contact user "andrie hartanto" about the AIM stuff, he is semi local and really knows the product
Old Feb 14, 2007 | 01:41 PM
I really like the SPA dual gauges but am not sure how they would be to read why'll racing.
Old Feb 14, 2007 | 01:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">I really like the SPA dual gauges but am not sure how they would be to read why'll racing.</TD></TR></TABLE>
thats why warning lights are good, if you set them high enough. And why being able to data log is that much better. because you can set back after the run and see if you had any pressure drops or temp spikes, and were and when they happened.
Although if your on a budget, the longacre stuff is fine. I haven't used any of there gauges but the tires and pit equipment is nice stuff.
170 for those 3 gauges is a good deal, but you might have to buy the pressure and temp sending units depending on what type of gauges they are.
Old Feb 14, 2007 | 02:01 PM
Default Re: anybody use them...........longacre racing products? (slammed_93_hatch)
How much did your AIM set you back with sending units and display?
Old Feb 14, 2007 | 02:09 PM
New User
Default Re: Racepak dash? (junkyard racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junkyard racer &raquo;</TD></TR><TR><TD CLASS="quote">dam, any idea of the cost of that? .</TD></TR></TABLE>
It's supposed to be around $650 I think, but no datalogging.
Old Feb 14, 2007 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 &raquo;</TD></TR><TR><TD CLASS="quote">How much did your AIM set you back with sending units and display?</TD></TR></TABLE>
I can't remeber, i have spent wayyyyy to much money over the last 6 months.
PM andrie he sells them and has all the info
Old Feb 14, 2007 | 02:33 PM
Ekasey's Avatar
Or you could do the easy thing, buy an AEM EMS, get an AIM MXL series and hook up the data stream and you're done, no wiring needed everything will display
Old Feb 14, 2007 | 03:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekasey &raquo;</TD></TR><TR><TD CLASS="quote">Or you could do the easy thing, buy an AEM EMS, get an AIM MXL series and hook up the data stream and you're done, no wiring needed everything will display</TD></TR></TABLE>
Not legal in H1
Old Feb 14, 2007 | 03:47 PM
Ekasey's Avatar
uh how is it not legal in H1?
Looks too me like theyt are unrestricted, and if that's not the case why was there one in an H1 car this weekend?
Please show me?&gt;
9.3 H1 Hybrid Vehicles Only
In addition to any unmodified part from any Honda or Acura model, market, or generation, the following
components are unrestricted:• Brake Systems
• Engine cylinder head porting (“from the block up”)
• Engine Management Systems
• Compression Ratio
• Fasteners (e.g. bolts) anywhere in the engine
• Valve preparation (angle, cut, etc) but not size or material
• Valve Springs, valve locks ,valve retainers, and valve shims
• Camshaft (except “K” series)
• Camshaft gears (including adjustable)
• Fuel Pumps, fuel Injectors, fuel rails
• Engine and transmission mounts, and associated components (shift linkages, etc) required to
perform an engine/drive train swap
Engine management systems (ECUs, piggyback computers, etc)• Any metal wheel (subject to 7.12(c) and 9.3.1(d))
• Battery type, size, voltage, and weight and location.
Old Feb 14, 2007 | 06:22 PM
I will be running the new H2 and already have a hondata s300
Old Feb 14, 2007 | 06:27 PM
Andrie Hartanto's Avatar
They are also working on having a Can bus system with Hondata. It is in the works.
If anyone interested in getting any AIM product, do let me know. For club racer budget the MyChron XGLog will work great. No need to get anything higher if you don't know how to use it. This data logger thingy is only as good as the operator.
Old Feb 14, 2007 | 07:37 PM
black3door's Avatar
Default Re: anybody use them...........longacre racing products? (Andrie Hartanto)
i'd concure with andrie
you only need 6 basic channels at first for logging
steering
lat and long G
throttle position
brake pressure
rpm
speed
anything more and you get confused with the squigglies. get that 6 downpat first before trying to read suspension histograms and all that jazz.
Old Feb 15, 2007 | 08:24 AM
CagedRuss's Avatar
Been using Longacre products for about 14 years when I used to built Late Models and open comp dirt cars. Still use the gauges and switches for the road race cars now.
Great service also.
Rikaro
Nov 24, 2007 05:42 AM
vtec.dc2
May 24, 2006 04:38 PM
thehammer
Mar 2, 2004 09:32 AM
