skunk2 manifold
Old Feb 14, 2007 | 10:55 AM
94whitegsi's Avatar
Default skunk2 manifold
i put i skunk2 manifold on my integra, and for some reason its slower, i got the stock throttle body on it i was wondering if that could be the reason ,and it rev to 2000rpm for a long time?
Old Feb 14, 2007 | 11:00 AM
WalkerGSR1's Avatar
Default Re: skunk2 manifold (97redtegra)
you need to raise vtec crossover, and get some cams then dyno TUNE!!!!
Old Feb 14, 2007 | 11:03 AM
94whitegsi's Avatar
Default Re: skunk2 manifold (WalkerGSR1)
how do i raise vtec crossover?
Old Feb 14, 2007 | 11:07 AM
litovi3tboi503's Avatar
vtec controller...
WalkerGSR1's Avatar
You need some sort of engine management, crome, hondata, neptune, uberdata etc.
Vtec controllers cant adjust the timing.
Old Feb 14, 2007 | 11:08 AM
Default Re: (WalkerGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">You need some sort of engine management, crom, hondata, neptune, uberdata etc</TD></TR></TABLE>
or this.. just get crome its cheaper.. and u can set vtec crossover on there
Old Feb 14, 2007 | 11:16 AM
iH8RICERZ's Avatar
which ecu are you running now? If your rpm is staying at 2k for a long time, you might have a vacuum leak or you may have to adjust your idle.
Old Feb 14, 2007 | 11:19 AM
WalkerGSR1's Avatar
Did you use the correct torque pattern, remove old gaskets and replace with new ones?
Old Feb 14, 2007 | 11:22 AM
94whitegsi's Avatar
am running obd1 p72 with hondata s200
Old Feb 14, 2007 | 11:25 AM
WalkerGSR1's Avatar
??? Take it to a tuner if you already have hondata. Get some type r cams to help with manifold.
Old Feb 14, 2007 | 11:29 AM
94whitegsi's Avatar
what if i put some skunk2 stage 1 turbo cams
Old Feb 14, 2007 | 11:32 AM
Default Re: (97redtegra)
do u have turbo???
Old Feb 14, 2007 | 11:34 AM
94whitegsi's Avatar
Default Re: (litovi3tboi503)
no
Old Feb 14, 2007 | 11:35 AM
going to turbo?
Old Feb 14, 2007 | 11:51 AM
WalkerGSR1's Avatar
Type r cams make more power on turbo over skunk2 cams. Search you'll find the threads on here somewhere.
Modified by WalkerGSR1 at 3:00 AM 2/15/2007
Old Feb 14, 2007 | 10:13 PM
turbodegsi's Avatar
i've got a gsr with skunk 2 manifold and stock tb with no tuning and it ran just fine..
i think you got other problems.. as far as reving to 2k all the time i second the vaccume leak..
now the gsr is turbocharged with the same manifold and it's even better..
recheck your gaskets and make sure everything put together right
jetspeedz
Aug 6, 2009 10:15 AM
motormike40
Jan 5, 2009 12:06 PM
crashzerothree
Aug 31, 2006 05:05 PM
allmotorjdism
Oct 10, 2005 04:45 AM
AK94GSR
Jun 11, 2003 02:24 PM
