Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 Civic pulling hard left during acceleration
Old Feb 13, 2007 | 04:57 PM
brooksall's Avatar
Default 03 Civic pulling hard left during acceleration
My 2003 Civic LX {manual transmission) pulls hard left only during acceleration. We've rotated tires front to back and side to side and had the front end realigned with no help. Any Ideas? Thanks
Old Feb 13, 2007 | 05:49 PM
Curiouz_G's Avatar
bad shocks or springs? i dunno just throwing out guesses. i know when my lower control arm was messed up it went toward the right so maybe thats it?
Old Feb 13, 2007 | 09:10 PM
Vantage's Avatar
can an engine mount do that?
Old Feb 13, 2007 | 10:11 PM
Miracle's Avatar
Default Re: (Vantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vantage &raquo;</TD></TR><TR><TD CLASS="quote">can an engine mount do that?</TD></TR></TABLE>
Eh...POSSIBLE.... but not LIKELY
Could be a worn ball joint, worn tie rods, something wrong with the tires, alignment.....
That is really all I could think of.
Old Feb 14, 2007 | 09:54 AM
tfnaaf's Avatar
actually, yes a bad engine mount /tranny mount can cause it by changing the cv-shaft alignment it causes torque steer. But could also be worn suspension parts
Old Feb 14, 2007 | 01:03 PM
02 turbo si's Avatar
Default Re: 03 Civic pulling hard left during acceleration (brooksall)
Turn your wheel to the right.....lol
Old May 9, 2007 | 03:01 PM
tofu man's Avatar
Default Re: 03 Civic pulling hard left during acceleration (02 turbo si)
bump for more info!!
I have had this same problem for 8 MONTHS!!!!!!!
Old May 9, 2007 | 03:35 PM
Newfie's Avatar
**DITTO** on this problem
Old May 10, 2007 | 12:31 PM
cherrynutz's Avatar
Default Re: (tfnaaf)
Just my strut (FR) going out made my car steer right during acceleration. I changed that out and I'm good now.
Old May 10, 2007 | 01:14 PM
tofu man's Avatar
Default Re: (cherrynutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherrynutz &raquo;</TD></TR><TR><TD CLASS="quote">Just my strut (FR) going out made my car steer right during acceleration. I changed that out and I'm good now. </TD></TR></TABLE>
Well, the gas is leaking from all four of my struts, and the car rides like ***.
Old May 10, 2007 | 06:30 PM
DJThomas1189's Avatar
Default Re: (cw.tech)
Wikipedia gives you some idea of whats going on or what could be going on.
Old May 10, 2007 | 11:19 PM
tofu man's Avatar
Default Re: (DJThomas1189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJThomas1189 &raquo;</TD></TR><TR><TD CLASS="quote">Wikipedia gives you some idea of whats going on or what could be going on.</TD></TR></TABLE>
Mind posting a link?
Old May 11, 2007 | 05:39 AM
http://en.wikipedia.org/wiki/Torque_steer
Old May 11, 2007 | 06:43 AM
mikelax125's Avatar
* B A N N E D *
ok i just put some tein flex coil overs on my 05 lx. and my car was towing in terrably. When i forst hit on it after the install i went left HARD. if your car is lowered or has coilovers i would meassure the distance between the front and back of your front wheals. mine was a 5 CM differance. The wheals were 5 CM closer togeathe rint he fornt then they wer ein the rear. hence causing the car to pull hard either way. Thatsjust another gusse though. I fixed it by adjusting my tire rods and i still need to go to some nasty alighnment shop. My advise to you go find a nasty alighnment shop and have them try! let me know if i cna be of any better help
Old May 11, 2007 | 06:45 AM
mikelax125's Avatar
* B A N N E D *
Default Re: (mikelax125)
i honestly dont think torque stear is the issue. our cars dont make enough power. stock that is
Old May 11, 2007 | 09:02 AM
BojeEM2's Avatar
It may be a broken motor mount because my friends ek kept stearing stongly to the right,then after about 2 weeks he broke a cv joint,replaced it and then broke the new cv joint.After all said and done, it was a broken motor mount
Old May 11, 2007 | 03:14 PM
chonda's Avatar
Yea I sort of have the same problem except my car doesn't pull to the left, it rattles a bit.
Old May 11, 2007 | 06:21 PM
tofu man's Avatar
One of the bolts that holds the back motor mount in my car is stripped, but I have energy suspension inserts in all the other mounts.
Old May 11, 2007 | 08:41 PM
raymundojr's Avatar
a broken motor mount could be the cause especially when turning the steering wheel so strongly carelessly it could break also the cvt joints.The good thing is to access wikipedia or replaces those shocks instead.
bibong
Apr 14, 2007 01:06 PM
Cee_mon
Jun 11, 2006 12:13 PM
verbose assassin
Nov 3, 2005 06:19 PM
flipcivicvtec
Apr 26, 2005 07:59 PM
Ri5e
Dec 31, 2001 09:41 AM
