b18c-r swap
Old Feb 13, 2007 | 03:06 PM
arielmalespin's Avatar
Default b18c-r swap
hey guys i currently have a 97 ex coupe wit a 99 b16a2 motor. Im running the si computer so i got the obd2a to obd2b harness, now i wanna purschace a 98 jdm b18c typer. wat problems would i run into wit this swap. Like for example i heard the jdm type r hub is 36mm and mines is 32mm so wat should i do? use usdm axle? and also the collector in the header is 2.5 inch would that be a problem? thanks for the info guys really appreciate it
Old Feb 13, 2007 | 08:19 PM
egsleepercivic's Avatar
use your si axles, get the exhuast fixed if need by a muffler shop, should be pretty straight forward, prolly wanna run the type r computer
Old Feb 14, 2007 | 09:13 AM
RaceCarRyne's Avatar
Default Re: (egsleepercivic)
i had a jdm r and axles were not a problem.. and it will be the exact same swap as the b16.. easy as pie
JulioRX
Aug 24, 2008 10:44 PM
EGB18
Jul 12, 2004 07:49 AM
cash459
May 3, 2003 10:53 PM
jdmciviceg
Feb 25, 2002 08:19 PM
