2000 accord turbo question?
I am finally ready to order a turbo kit and Turbokits.com discontinued the kit for my 2000 accord coupe. I did get some good info on here about pistons and connecting rods from raceeng.com Are these good pistons and rings for the turbo? And please can anyone recommend where I should get my turbo kit for my car. Thanks
yes the pistons/rods that Race Engineering has are very good quality.
I got my drag kit from ben at importparts.com. If you are handy you can piece a "kit" together for cheaper than a pre-fabbed one.
Enlarge Image
98-02 2dr 4cyl TURBONETICS TURBO KIT
Turbonetics Turbo Systems include everything you need from fuel and ignition to piping and fittings for complete bolt-on turbo performance. Pieces mount to existing factory positions and maintain all optional equipment including air conditioning. Kits can usually be installed within 8 - 12 hours. The fuel and ignition management systems come pre-programmed to maintain a consistent air/fuel ratio and timing control under all conditions.
Kit Includes:
Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid)
Spearco Intercooler System
Powder-Coated Intercooler Piping
Silicone Hose / T-Bolt Clamps
Exhaust Manifold - high carbon cast-steel with ceramic coating
Fuel / Timing Controller (electronic fuel / timing management system)
Fuel Injectors
"Evolution" Wastegate Assembly
"Raptor" By Pass / Blow Off Valve Assembly
Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge
Intake System with Air Filter
All necessary Hardware, Hoses, and Fittings
1 case of TS-1 Synthetic Motor Oil
WW.TASAUTO.COM
xkrntamax
Jan 12, 2008 02:05 PM
