Tranny problems
Old Feb 13, 2007 | 09:16 AM
ChinitodeNJ's Avatar
Default Tranny problems
I have a 92 Dx Hatch with a 98 Dx stock motor in it. The other day I was driving and stopped at a light. When the light turned green I tryed to shift into first but it wouldnt let me. Then I tryed to take off in second (I was on the highway with alot of cars beeping at me...) and it wouldnt let me shift there either. Then after playing with it for a couple of seconds it finally went into first. At first I thought it was my shift linkage. But then my 3rd and 4th gear began to pop out of gear sometimes. I've searched all morning for this but had no luck. Any suggestions?
Old Feb 13, 2007 | 09:19 AM
Mario_D's Avatar
Default Re: Tranny problems (ChinitodeNJ)
1. You may be low on tranny fluid. You will have to check.
2. You clutch master cylinder may be low on fluid. Again, you will have to check.
Also, was there any grinds when you where shifting?
m-
Old Feb 13, 2007 | 09:21 AM
Default Re: Tranny problems (Mario_D)
Well my third gear use to grind a little bit before but not the bad. Also when I turn the car up in the morning it makes a wierd nose like a dragon fly flapping its wings( couldnt think of anything else to describe it lol)
Old Feb 13, 2007 | 09:23 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario_D &raquo;</TD></TR><TR><TD CLASS="quote">1.
m-</TD></TR></TABLE>
this i would have too agree on, but this,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario_D &raquo;</TD></TR><TR><TD CLASS="quote">1. You may be low on tranny fluid. You will have to check.
this should never leak. unless it's seeping from somewhere crack, plugs, or seals. then there is a different problem that has to be addressed.
Old Feb 13, 2007 | 09:27 AM
Default Re: Tranny problems (philosofy1)
Oh yea sorry guys but I forgot to tell you that I never had any leaks from my car. This morning I noticed my driveway had spots from my car. So I took a look under my car and saw some tranny fluid leaking...sorry again for not putting this earlier..
Old Feb 13, 2007 | 09:28 AM
Mario_D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
this should never leak. unless it's seeping from somewhere crack, plugs, or seals. then there is a different problem that has to be addressed.</TD></TR></TABLE>
Very true. Just some pointers for OP to look at. I too have not seen a completely sealed tranny go low on fluid.
m-
Old Feb 13, 2007 | 09:42 AM
Any more suggestions?
Old Feb 13, 2007 | 09:45 AM
Mario_D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChinitodeNJ &raquo;</TD></TR><TR><TD CLASS="quote">Oh yea sorry guys but I forgot to tell you that I never had any leaks from my car. This morning I noticed my driveway had spots from my car. So I took a look under my car and saw some tranny fluid leaking...sorry again for not putting this earlier..</TD></TR></TABLE>
Now you have to find where the leak is.
1. Axle seals
2. Loose drain plug
3. Cracked tranny housing
4. Loose countershaft plug
5. Loose fill plug
You can start there.
m-
Old Feb 13, 2007 | 09:48 AM
Thanks for your help guys
teggy_617
May 14, 2009 05:21 PM
NOOdS
Apr 20, 2009 11:04 AM
SBI ONE
Jul 27, 2005 08:18 AM
91_2.0_Si
May 20, 2004 07:05 PM
3rdGteg
May 7, 2002 10:23 PM
