Whose all NOT running front torque mounts?
How many of you are not running torque mounts (both front, tranny and ac bracket) with your swap? Just wondering if it would be safe to run without them. Using 75a grade mounts for the other motor mounts btw.
if you want the motor to hit the hood.
I ran my car without the tranny side torque mount at the track for one event, I was launching at 6000rpm, and the motor/turbo manifold ripped through the hood of my freshly painted car.
I've got no ac mount and it works ok. I've seen a few trannies break off where the rear L bracket mounts due to a bad rear mount and lack of torque mounts, but if the rear mount was good, I doubt they would've had that problem. I guess it just depends on how you drive, if you're dropping the clutch at high rpms like the previous guy, I'd run them.
if u have hasports, other man mounts u should be fine.. otherwise ur hood will get hit by the motor. as the mounts are there to stop the motor from moving up and down and all around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">if u have hasports, other man mounts u should be fine.. otherwise ur hood will get hit by the motor. as the mounts are there to stop the motor from moving up and down and all around
I'm running Innovative mounts with the 75a inserts.
</TD></TR></TABLE>I'm running Innovative mounts with the 75a inserts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnShiwota »</TD></TR><TR><TD CLASS="quote">Thas the same setup thats on my friends car. Had it on there for the last year with no probs at all
What's his set up?
</TD></TR></TABLE>What's his set up?
yea man, my car doesnt have them and my motor moves everywhere....you prob should used them or get a Motor Torque Damper to help out.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg »</TD></TR><TR><TD CLASS="quote">I have Avid mounts with no ac mount and its fine.</TD></TR></TABLE>
Still running tranny side tho?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">
Still running tranny side tho?</TD></TR></TABLE>
Ya, I don't trust removing the tranny side, and I would rather have the stiffer motor than loss of 5 lbs personally.
97grnrs
Nov 20, 2008 08:46 PM
whoneedzvtec
Nov 21, 2007 04:13 AM
doesnt bolt up to my ls trans
