Alignment?????
Old Feb 12, 2007 | 08:15 PM
ware's Avatar
Default Alignment?????
i have new tires in the rear, and front tires have inner wear (not an even wear) when above 50+ mph the car pulls to the right. I am lowered and when i had my old rims w/ tires this did not happen, recently got these 15'' slips with used tires. any suggestions on what can fix the problem?
Old Feb 12, 2007 | 08:22 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: Alignment????? (ware)
alimentment and camber/washer trick should be done :D
Old Feb 12, 2007 | 08:30 PM
ware's Avatar
Default Re: Alignment????? (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote"> camber/washer trick should be done :D </TD></TR></TABLE>
thanks for the info bro. but not familiar with what a camber/washer trick would be... (kinda new with this whole suspension stuff) any help is appreciated
Old Feb 12, 2007 | 09:22 PM
bmoua's Avatar
http://home.earthlink.net/~civ....html
there you go bro...have the washer trick and works great...
Old Feb 13, 2007 | 07:26 AM
ware's Avatar
Default Re: (bmoua)
this only works on the rear right?thanks for the help guys
Old Feb 14, 2007 | 12:20 PM
ware's Avatar
aww **** man.. took the car to get aligned today and they told me that they will align it but hat it would be a waste of my money because it will go back to the same way it was before, they said that because the wheels are like this /---\ they cannot align it and gurantee their work , as a matter of fact they tolds me it would be worthless to align it. I told them what if i got a camber kit and they said that the fender would be in the way and would cost more.. so they told me they can press the arm or something like that and they get the wheels straight then align it but im looking at somewhere round $250 for their work.. dont know what to do guys. thinking just getting some 16'' and not lower it alot .. but really wanna stay with the 15'' .. need to solve this problem.. any suggestions on what i should do?
Old Feb 14, 2007 | 12:42 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">i have new tires in the rear, and front tires have inner wear (not an even wear) when above 50+ mph the car pulls to the right. I am lowered and when i had my old rims w/ tires this did not happen, recently got these 15'' slips with used tires. any suggestions on what can fix the problem?</TD></TR></TABLE>
the problem are the tires not the rims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">aww **** man.. took the car to get aligned today and they told me that they will align it but hat it would be a waste of my money because it will go back to the same way it was before, they said that because the wheels are like this /---\ they cannot align it and gurantee their work , as a matter of fact they tolds me it would be worthless to align it. I told them what if i got a camber kit and they said that the fender would be in the way and would cost more.. so they told me they can press the arm or something like that and they get the wheels straight then align it but im looking at somewhere round $250 for their work.. dont know what to do guys. thinking just getting some 16'' and not lower it alot .. but really wanna stay with the 15'' .. need to solve this problem.. any suggestions on what i should do?
they are the biggest idiots, actually, the biggest cons as well. yes they can align you car without any camber kits. having any negative camber has nothing to do with it. and yes if you install a camber kit it will help, but no, it will not hit your fender and it will not cost more (some places charge alittle extra for lowered cars, regardless of you have a kit).
there is no press or tool they can use to straghten it out, only a kit will help. and if you think tire wear is bad now, it's be alittle worse with bigger rims.
IMO, get yourself a camber kit, prefferably one that goes on the a-arm. those are easier to install, install it and take it to someone who knows what the hell they are doing and won't rip you off.
Old Feb 14, 2007 | 03:40 PM
ware's Avatar
so my problem is that i need an alignment or that i need a camber kit? or both? what if i just go get an alignment.. will that help?
Old Feb 14, 2007 | 04:11 PM
bmoua's Avatar
pmed you bro...
Old Feb 14, 2007 | 06:18 PM
ware's Avatar
really appreciate the help bmoua
cilvia
Mar 23, 2011 05:28 PM
jordancrockett
Dec 7, 2008 12:54 AM
Nicks95GSR
Dec 22, 2006 07:56 AM
VtecFreePrelude
Sep 29, 2006 08:21 AM
b16a2EBP
May 8, 2006 12:47 AM
