rod knock?
Old Feb 12, 2007 | 07:42 PM
bseries_ben's Avatar
Default rod knock?
how could i tell if i have a rod knocking?
Old Feb 12, 2007 | 08:00 PM
92TypeR's Avatar
FSAE
Default Re: rod knock? (clover99b18c1)
Do you have a knocking noise that is RPM dependent and also occurs when the car isn't moving?
Old Feb 12, 2007 | 08:02 PM
Default Re: rod knock? (92TypeR)
yes.
but... it doesn't always happen and a lot of times, it stops when im stopped. i've heard of instances when that noise was produced because one of the rod bolts was loose. how can i get to those to check?
Old Feb 12, 2007 | 08:30 PM
92TypeR's Avatar
FSAE
Rod knock is usually indicative of a scored rod bearing that cannot hold oil pressure. Eventually, if the bearing isn't replaced, it can sieze, then the rod usually ends up in 10 pieces and there will be a nice hole in the front of your block
Old Feb 12, 2007 | 09:14 PM
92TypeR's Avatar
FSAE
Buy a Helms manual (or download), that should answer a lot of your questions.
Old Feb 13, 2007 | 04:53 AM
um ok. thanks
leem23vtec
Nov 4, 2010 04:34 PM
qazaq
Dec 30, 2008 06:57 PM
B20zvtecek
Oct 28, 2002 01:35 AM
Random.Hero
Apr 18, 2002 09:27 PM
