cam gears?
Old Feb 12, 2007 | 06:25 PM
dohc_profile's Avatar
Default cam gears?
whats the purpose of racing cam gears?
Old Feb 12, 2007 | 06:43 PM
doood's Avatar
been there done that
Default Re: cam gears? (sohc_mnstr)
they let you dial in overlap of the cams as well as moving the powerband around some
Old Feb 13, 2007 | 07:00 PM
mosher111's Avatar
Default Re: cam gears? (doood)
how hard are they to set? I know you can loosen the nuts and adjust them but what are the basics of it all? I been concidering getting some & does it require any type of tunning?
Old Feb 13, 2007 | 07:46 PM
roger93si's Avatar
Default Re: cam gears? (mosher111)
from what i heard the right way to install this cam gears is to have someone tune your engine afterwards
Old Feb 13, 2007 | 07:48 PM
mosher111's Avatar
but tunning to what extent is what i wanting to know
Old Feb 14, 2007 | 03:20 AM
in addition to my first post, i also want to know will u gain decent hp from upgrading your cam gears?
Old Feb 14, 2007 | 12:37 PM
doood's Avatar
Default Re: cam gears? (roger93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mosher111 &raquo;</TD></TR><TR><TD CLASS="quote">how hard are they to set? I know you can loosen the nuts and adjust them but what are the basics of it all? I been concidering getting some & does it require any type of tunning?</TD></TR></TABLE>
you need to have them tuned on a dyno. if you have big cams and pistons with a big dome, advancing them too far can lead to piston to valve contact. not good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_mnstr &raquo;</TD></TR><TR><TD CLASS="quote">in addition to my first post, i also want to know will u gain decent hp from upgrading your cam gears?</TD></TR></TABLE>
from just the gears on stock cams? not much. paired with bigger cams, varies.
misterpsycho
Jan 14, 2008 10:54 AM
rdssk8rcs1
Nov 20, 2007 08:29 AM
JDMflavor_EJ
Aug 7, 2005 04:29 PM
CBR
Jul 31, 2005 08:51 PM
kuki
Feb 15, 2005 01:59 PM
