O2 Sensor Fix
http://twincamtech.stores.yahoo.net/blcelelad.html
Do these work to turn off the CEL when a race header is installed? It says it will work on various 96-up cars but have any of you guys used it?
Thanks,
Frankie
Thanks,
Frankie
If I was to put that on the car when the header is installed I wont have a DTC. I just want the light to be off so it'll come on if/when something else goes wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Type R »</TD></TR><TR><TD CLASS="quote">http://twincamtech.stores.yahoo.net/blcelelad.html
Thanks,
Frankie</TD></TR></TABLE>
**** that piece looks like it'll work alot better than the two-piece non-fouler i've been using that keeps breaking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ »</TD></TR><TR><TD CLASS="quote">The part may turn the CEL off but the DTC will still be stored ... I wouldnt call it a "fix" necessarily </TD></TR></TABLE>
What happens when the DTC is stored?? How do you get rid of it??
Thanks,
yeah, that will work perfectly. It doesnt actually turn the engine light off, it just doesnt allow a problem to happen. If you read the caption underneath it, it says what it does. When you put a test pipe/race header in there, that o2 sensor recieves a whole hell of a lot more air then when a cat is there. Since there is so much more air it cant get a proper reading which is a problem for the computer, so it throws a code. So that part just pulls it directly out of the flow and lets a lot less air in like when there is a cat there, which lets it get a proper reading which tricks the computer into thinking everything is fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">yeah, that will work perfectly. It doesnt actually turn the engine light off, it just doesnt allow a problem to happen. If you read the caption underneath it, it says what it does. When you put a test pipe/race header in there, that o2 sensor recieves a whole hell of a lot more air then when a cat is there. Since there is so much more air it cant get a proper reading which is a problem for the computer, so it throws a code. So that part just pulls it directly out of the flow and lets a lot less air in like when there is a cat there, which lets it get a proper reading which tricks the computer into thinking everything is fine. </TD></TR></TABLE>
Not a problem. I already know how to reset the CEL so once it's off hopefully it will stay off with this piece. I just need one that isn't going to break on me cause this is alot easier than putting in an O2 sim.
FAb5
Honda Civic (2006 - 2015)
28
Dec 30, 2009 08:22 PM
ricanzxrebel
May 11, 2007 10:08 PM
- BSeRiouS -
Honda S2000
Sep 6, 2006 10:09 PM
JDMREVELATIONS
Jun 8, 2005 09:45 PM
