compression test figures
Old May 19, 2002 | 02:57 PM
mugenracer's Avatar
Default compression test figures
I done a compression test yesterday and got 150 150 150 155 on my JDM b18C integra...from reading through other topics i see that USDM figures are around the 200 mark. Is this very low for my car...my friend has a euro civic VTi with B16A engine he checked his after mine and got 135 approx on all 4 cylinders so we reckoned that mine was probably right. His engine is completely stock, with only 38k miles and it doesnt use any oil at all so its safe to say his engine is in fairly good condition, but i still think 150 is too low on my car, and if its is low how come the numbers are so even across the board?
Old May 19, 2002 | 03:27 PM
Chiovnidca's Avatar
Default Re: compression test figures (mugenracer)
Those numbers look fine. I don't see a problem.
Old May 19, 2002 | 03:46 PM
All Motor EG's Avatar
i just did my compression check got 240 in all 4
Old May 19, 2002 | 04:07 PM
SEFIxCivic's Avatar
are you doing it with the engine warm, throttle open & are you using a reliable gauge? those numbers are really low. should be like 210-220
Old May 19, 2002 | 04:08 PM
mugenracer's Avatar
Default Re: compression test figures (All Motor EG)
what engine and what pistons are you running..stock??
Jeez that makes me worry that mine are too low..anyone know what JDM B18C figures should be at??
Old May 19, 2002 | 04:14 PM
mugenracer's Avatar
Default Re: compression test figures (SEFI8LOxCivic)
yes the engine was warm/hot but the throttle wasnt open, just cranked engine till gauge stopped moving
Old May 19, 2002 | 04:17 PM
SEFIxCivic's Avatar
opening the throttle usually makes a difference try that and see how it works out for you. with the throttle open is the proper procedure.
Old May 19, 2002 | 04:18 PM
raene's Avatar
Yikes... Throttle should be held in the wide-open position. Try doing that and see if it changes your numbers.
Old May 19, 2002 | 04:19 PM
mugenracer's Avatar
as you might have seen in another post i screwed up my distributor doing the check...didnt realise i had to pull the ecu fuse and so burnt out the coil, so i have to wait till i get new coil before re-checking
Old May 19, 2002 | 04:28 PM
Doctor CorteZ's Avatar
ouch , those seem REALLY low
Old May 19, 2002 | 04:33 PM
mugenracer's Avatar
Default Re: compression test figures (Doctor CorteZ)
yeah i figured that they were too low, but at least theyre all even which is a good sign, i'll do it again the proper way and see what numbers i get!
Old May 19, 2002 | 05:09 PM
Lsvtec with p30 pistons around 11:5:1 compresion
Old May 19, 2002 | 08:33 PM
non-VTEC's Avatar
maybe the compression tester guage is bad/inaccurate?
my 95 LS put 175-180psi in all 4 cylinders
Old May 20, 2002 | 10:12 AM
mugenracer's Avatar
Default Re: compression test figures (non-VTEC)
i think that it was more the guy using it was faulty more so than the gauge itself which was brand new...if only i had read my crappy haines manual it tells exactly how to do it...which is of course totally different to the way it was done...and hence the toasted coil and me having to drive a POS till i get a new coil on wednesday. I spoke to another guy at a tuning shop today and when i was telling him how the test was done i could see him screwing up his face in disbelief...why didnt i just bring it to him in the first place...anywho no point in crying over spilt milk, the other guy is going to the comp test again on friday so hopefully i should see some better figures.
Old May 20, 2002 | 01:40 PM
erniecars's Avatar
i had that same problem with low numbers but i think my tester was leaking. thats what you get for $20. but if all the numbers are really close you're probably ok.
Old May 20, 2002 | 02:42 PM
mugenracer's Avatar
Default Re: compression test figures (erniecars)
the guage was made by TENG tools and they are not cheap..bad operator was the problem...anywho he has agreed to pay for whatever it costs to repair the damage!
Old May 20, 2002 | 05:40 PM
mick's Avatar
when i did mine a while ago i got 160, 160, 160, 120 (120 in cylinder 1, haven't quite worked out why yet, i think its either coz the head is warped or coz the valves aren't sealing properly), JDM 89 integra XSi, 147k's
Old May 21, 2002 | 02:35 PM
EVOCELICA's Avatar
New User
http://www.c-speedracing.com/howto/c.../comptest.html
do the compression test again and do it exactly as it is said in this how to article the motor must be hot and the throttle must be open all the way while turning over.
Type 56
Engine Machining & Assembly
Aug 13, 2017 06:34 PM
turbotime
Oct 1, 2005 08:46 AM
Jonathan_ED3
Oct 28, 2004 03:31 PM
Greenery18
Jul 6, 2004 08:29 AM
Metal_SOL
Aug 9, 2002 12:05 AM
