Going through Silverstars every other week...
Old Feb 12, 2007 | 11:11 AM
WhiteOnRice's Avatar
Default Going through Silverstars every other week...
Okay, first a little background:
Low beam: H1, Silverstars, last about 2 weeks
High beam: H1, bulbs came with headlight, have lasted 13 months
I've had projectors for about 9 months with wire connectors from TYC with no problems except flickering because the connectors would come loose. About 6 months ago I started using SilverStars low beams. They worked great for 4 months until I switched wire connectors, trying to fix the flickering problem.
I used some kind of twist connectors, from the auto department of Wal-Mart (SHOULD be able to use on a CAR). I used wrapped them (heavily) in electrical tape in attempt of keeping out water. But they have been burning out excessively and I want to sell the car w/o problems.
Is it the connectors causing the problem? If so, what type could I use? I know stock, but I don't have them anymore. It's strange that only the SilverStars are burning out. Maybe it's the combination of Silverstars/connectors. HELP!
THanks a lot guys
Old Feb 13, 2007 | 09:12 AM
Bump
Old Feb 13, 2007 | 09:16 AM
Manga_Spawn's Avatar
Default Re: (fizix_skate)
Why not go back to the TYC connecters and try to secure them so they don't get loose? What do you mean by connectors anyway? The plung in things? Just zip tie them so they stay plugged in. Pictures would help but I would say go back to the other wires/connectors because the walmart crap is well crap.
Old Feb 13, 2007 | 09:17 AM
Also you are not touching the bulbs right? If you touch the bulb it kills it alot quicker.
Old Feb 14, 2007 | 08:19 AM
dad0c402's Avatar
Default Re: Going through Silverstars every other week... (fizix_skate)
try rewiring it back to the way it started using crimps and connectors that give solid connections. If not use the factory headlight wiring and a DIY relay harness.
Old Feb 14, 2007 | 08:23 AM
MidwestSiR's Avatar
I'm on my third and LAST set of Silverstars. They're known to blow especially in sudden cold weather.
Great bulbs when they work
Old Feb 14, 2007 | 06:50 PM
Default Re: (Manga_Spawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manga_Spawn &raquo;</TD></TR><TR><TD CLASS="quote">Why not go back to the TYC connecters and try to secure them so they don't get loose? What do you mean by connectors anyway? The plung in things? Just zip tie them so they stay plugged in. Pictures would help but I would say go back to the other wires/connectors because the walmart crap is well crap.</TD></TR></TABLE>
Good idea but I cut the wire really short. What can I do about this?
Old Feb 15, 2007 | 08:33 PM
Is there a company that makes "weather secure" connections or should I just go to a junkyard?
Old Feb 19, 2007 | 06:18 PM
Bump for blowing another
Old Feb 19, 2007 | 06:31 PM
gents97civ's Avatar
Try to solder the wires up good. Then use brush on electrical tape. Make sure when you install the bulbs you do not touch the glass. The oil from your fingers causes a hot spot on the bulb, and causes them to blow prematurely.
Old Feb 19, 2007 | 07:02 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (gents97civ)
silverstars are also known to blow premeturley becuacse of low quality , get piaa's
Old Feb 19, 2007 | 08:05 PM
dcsports's Avatar
Default Re: (spork motorsports)
piaa's mess up also been thru many of those just get damm hid's
Old Feb 20, 2007 | 05:33 PM
blueb16-em1's Avatar
had my silverstars for 8+ months now, still working well
Old Feb 26, 2007 | 07:38 PM
I bought $5 Slyvania's or something from Wal-Mart and they have lasted a week! Through rain, bad wintery mix and turning them on and off quickly for a good minute.
Old Feb 26, 2007 | 07:54 PM
2wheelhunter's Avatar
had the same problem with my old RSX-s i think it was grounded somewhere where it shouldnt have been, becuase it only happend on one side
Old Feb 28, 2007 | 06:07 PM
It's not the same problem if it only happened on one side.
Old Feb 28, 2007 | 06:42 PM
k.'s Avatar
k.
New User
Default Re: (blueb16-em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueb16-em1 &raquo;</TD></TR><TR><TD CLASS="quote">had my silverstars for 8+ months now, still working well</TD></TR></TABLE>
same here.
~k.
Old Feb 28, 2007 | 06:59 PM
Stock headlight/harness k.?
tupakiz
Nov 18, 2010 04:22 PM
Gamma Ray
Dec 23, 2009 07:02 PM
WhiteOnRice
Feb 13, 2007 09:12 AM
Volfrosh88
Dec 19, 2006 03:03 PM
darkEN4thgenlude
Jan 5, 2006 06:04 PM
