speedometer gone crazy?
i was warming up the hatch the other day and idling when i saw the speedometer jump to around 40mph then back down again
is this a sign of my cluster failing or is it my vss?
also when i ripped it a while back, i was around 60mph when the needle backed down to 40mph and jumped back to the correct speed. i didnt bog or anything.
sounds like a VSS to me. I wouldnt worry about it until it does it more often. or you can just be safe and change both.
i just went through a lot of **** trying to figure out why mine was jumping.
I have been pulling the plug a lot lately, by doing so i damaged the pins inside of the plug to the VSS
I tried a new cluster and VSS b4 i figured it out./
good luck
good luck
