Knock Sensor replacement/removal
Old May 19, 2002 | 12:27 PM
B_CRUZ!'s Avatar
Default Knock Sensor replacement/removal
i recieved my swap from IAS with a damaged KNOCK SENSOR. they sent me a new one and i was wondering if there is anything in particular i should look out for when installing this. will any fluids come out?
TIA
Old May 19, 2002 | 12:30 PM
sgT's Avatar
sgT
Default Re: Knock Sensor replacement/removal (B_Cruz)
no fluids
just remove old, install new.
Old May 19, 2002 | 02:50 PM
B_CRUZ!'s Avatar
Default Re: Knock Sensor replacement/removal (sgT & TEKEN)
thanks for the info guys. good thing i have a Skunk2 manifold though because it would be really hard to reach with the stock gs-r manifold.
Old May 19, 2002 | 03:30 PM
Chiovnidca's Avatar
Be sure to torque it to the proper spec.
Old Feb 3, 2003 | 12:14 AM
T_Rex's Avatar
Default Re: Knock Sensor replacement/removal (Chiovnidca)
bump
I'm about to do this and I'm wondering how I get to it without taking the intake manifold off. Can I access it by removing the oil filter?
Also, do you know what size socket I need?
Thanks a lot!
Old Feb 3, 2003 | 07:02 AM
B_CRUZ!'s Avatar
Default Re: Knock Sensor replacement/removal (T~Rex)
wow this thread is from 5/19/02... no need to remove the oil filter. I forgot the socket size but it is real easy to do.
Old Feb 3, 2003 | 11:08 AM
T_Rex's Avatar
How do you access it with the engine in the car then? I tried from underneath the car, but I couldn't see it...I could only feel it. And I don't think there's any way to do it from above.
Does anyone know the socket size needed?
[Modified by T~Rex, 12:09 PM 2/3/2003]
Old Feb 3, 2003 | 11:12 AM
dilligaph's Avatar
not sure if its the same setup, but in my lude its very easy to get at when i have the car up in the air.... maybe its harder to see if youre only using a jack, lifts rule.
Old Feb 3, 2003 | 11:15 AM
B_CRUZ!'s Avatar
i did it from above with no problems...
Old Feb 3, 2003 | 11:40 AM
T_Rex's Avatar
Man, I can't imagine how? I can barely get my hand in there, let alone a wrench or socket.
Old Feb 3, 2003 | 11:45 AM
B_CRUZ!'s Avatar
I have a gs-r motor with a skunk2 mani
Old Feb 3, 2003 | 12:43 PM
-Whitey-'s Avatar
i just changed mine yesterday on my b16a i did it from above its pretty easy and the socket you need is a 26mm deep thin wall what are you supposed to tourqe it to? i just hand tightened it and then a small extra turn for good luck
Old Feb 3, 2003 | 01:13 PM
T_Rex's Avatar
Default Re: Knock Sensor replacement/removal (FF-Panda)
Thanks, dude. What about wiring it to the ECU...was that very difficult? I bought my CRX with the swap, so I've never messed with the wiring. The thing I'm not sure about is how/where to route the wire into the passenger footwell area.
Old Feb 3, 2003 | 02:20 PM
-Whitey-'s Avatar
i dont know about wiring it becaus mie was pre wired all i had to do was plug it in and drive away
Old Feb 3, 2003 | 08:23 PM
T_Rex's Avatar
Anyone know?
entails
Sep 28, 2008 10:07 AM
ek-g6
Dec 30, 2007 02:21 PM
Derek88
Jun 17, 2007 03:47 PM
driftinflyboy
Jul 11, 2006 11:01 AM
Dogginator
Jul 10, 2006 08:45 AM
