Front LCA and sway bar install on EG help?
Old Feb 11, 2007 | 01:16 PM
vietfella's Avatar
Default Front LCA and sway bar install on EG help?
Does anyone know what happened to the FAQ with the front LCA install on an EG?
I thought i came by it before but i don't see another one. Need to install DC2 front LCA with ITR front sway.
Thanks.
Old Feb 11, 2007 | 05:42 PM
BlueIntegraBoy's Avatar
Default Re: Front LCA and sway bar install on EG help? (vietfella)
https://honda-tech.com/zerothread?id=879554
Old Feb 11, 2007 | 10:41 PM
vietfella's Avatar
Default Re: Front LCA and sway bar install on EG help? (BlueIntegraBoy)
thanks. thats exactly what i was looking for.
Old Feb 12, 2007 | 12:40 AM
To make install easier and to avoid ripping that nut off trying to remove the LCA, you can just remove the "A" part of the LCA and the leave the "I" part bolted up. I did this method because I didn't want to undo the tack welded nut.
Old Feb 12, 2007 | 12:42 AM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">To make install easier and to avoid ripping that nut off trying to remove the LCA, you can just remove the "A" part of the LCA and the leave the "I" part bolted up. I did this method because I didn't want to undo the tack welded nut.</TD></TR></TABLE>
Smart guy
Fnix
Suspension & Brakes
Nov 20, 2012 07:31 AM
Cuong-nutz
10
Oct 26, 2005 07:13 PM
Asild
Mar 18, 2002 04:05 PM
