Oil pressure/Volt guage
Old Feb 11, 2007 | 09:07 AM
zach1288's Avatar
Default Oil pressure/Volt guage
I want to install an oil pressure and volt guage in my car. How hard is it to do this? Is there a write-up anywhere on the net that might show me how to do this? Thanks
Old Feb 11, 2007 | 11:44 AM
zach1288's Avatar
bump
Old Feb 13, 2007 | 06:41 AM
zach1288's Avatar
Default Re: (zach1288)
Bump
Old Feb 13, 2007 | 06:51 AM
jz98ctr's Avatar
do you already have these gauges or are you still looking to buy them?
oil pressure is pretty easy but you have to do it right so you don't have any leaks.
voltmeter is a cakewalk...2 wires...ignition and ground.....ok maybe 3 wires cuz you might want to hook it up to your lights too
Old Feb 13, 2007 | 08:53 AM
zach1288's Avatar
Default Re: (jz98ctr)
Im still looking to buy them, how do you install a oil pressure guage?
Old Feb 13, 2007 | 05:37 PM
eg9matt's Avatar
next to your oil filter there is a plug it is the oil pressure sensor unscrew it and screw in the oil line it should be 1/8 if you are using a mechanical gauge then run the line to your gauge and hook up the wires and ur good to go good luck
Old Feb 14, 2007 | 03:29 PM
jz98ctr's Avatar
Default Re: (eg9matt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg9matt &raquo;</TD></TR><TR><TD CLASS="quote">next to your oil filter there is a plug it is the oil pressure sensor unscrew it and screw in the oil line it should be 1/8 if you are using a mechanical gauge then run the line to your gauge and hook up the wires and ur good to go good luck</TD></TR></TABLE>
right...however...if your running a stock ecu and remove the stock oil pressure sensor...it might throw a code...so what you might have to do is get a T-fitting (or something similar) allowing you to put your stock sensor back in AND the aftermarket gauge line
Old Apr 1, 2007 | 09:32 AM
zach1288's Avatar
Where should i buy these gauges? and is there any write ups on installing them?
Old Apr 2, 2007 | 01:17 PM
zach1288's Avatar
Where should i buy these gauges? and is there any write ups on installing them??
twentyhurtz
Dec 7, 2008 09:17 AM
EFsideways
Jan 1, 2008 01:52 PM
9hatch6
17
Apr 24, 2005 04:08 PM
poppycock
15
Mar 18, 2004 03:20 PM
accordfreak
Jan 27, 2004 12:52 PM
