1994 civic Ex w/ gsr swap *need info on motor mounts*
Old Feb 10, 2007 | 06:44 PM
Fat Chick Magnet's Avatar
Default 1994 civic Ex w/ gsr swap *need info on motor mounts*
doing a gsr swap in a 1994 EX coupe so can i just buy 94-01 integra innovative motor mounts since its 3 bolt post mount? will i also need the rear L bracket w/ the innovative mounts?
Modified by dc2rtek at 8:06 PM 2/10/2007
Old Feb 10, 2007 | 06:52 PM
do i buy 2 bolt pattern
or 3 bolt pattern
Old Feb 10, 2007 | 07:34 PM
Luserkid's Avatar
Default Re: (dc2rtek)
The "3bolt" looks like the upper driver mount you need but that looks way thicker then a stock mount. You need the GSR bracket.
Old Feb 10, 2007 | 07:39 PM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">The "3bolt" looks like the upper driver mount you need but that looks way thicker then a stock mount. You need the GSR bracket. </TD></TR></TABLE>
so it only has to be a gsr bracket? i cant use any b-series like LS, Em1 Si...
Old Feb 10, 2007 | 09:17 PM
Luserkid's Avatar
Any 94-01 integra bracket will work.
Old Feb 10, 2007 | 09:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Any 94-01 integra bracket will work. </TD></TR></TABLE>
thanks.
Old Feb 10, 2007 | 09:34 PM
so before i order everyone agree i should buy 94-01 integra innovative motor mounts?
JayDeeMmm
Apr 15, 2011 06:12 PM
mattltos
May 6, 2010 07:06 PM
lyzer227
Jul 6, 2009 01:44 PM
GOLDBERG
Nov 15, 2003 06:37 AM
